32K153-400L5
32K153-400L5
    ROSENBERGER
    插件
    SMA 连接器 插孔,母形插口 50 欧姆 通孔 焊接
32K153-400L5 数据手册
TECHNICAL DATA SHEET SMA Economy 32K153-400L5 STRAIGHT JACK PCB All dimensions are in mm; tolerances according to ISO 2768 m-H Interface According to IEC 60169-15; EN 122110; MIL-STD-348 Documents PCB layout see drawing Material and plating RF_35/11.05/3.1 Connector parts Center contact Outer contact Dielectric Material Plating Beryllium copper AuroDur, gold plated Brass AuroDur, gold plated PTFE Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel.: +49 8684 18-0 Page email: info@rosenberger.de 1/2 TECHNICAL DATA SHEET SMA Economy 32K153-400L5 STRAIGHT JACK PCB Electrical data Impedance Frequency VSWR 50 Ω DC to 12.4 GHz ≤ 1.1 + 0.01 x f [GHz] Insertion loss Insulation resistance Center contact resistance Outer contact resistance Test voltage Working voltage Power handling (at 20 °C, sea level, VSWR 1.0) RF-leakage ≤ 0.05 x f(GHz) dB ≥ 5 x103 MΩ ≤ 3 mΩ ≤ 2 mΩ 1000 V rms 480 V rms ≤ 200 W @ 2 GHz ≥ 100 dB up to 1 GHz - VSWR in application depends decisive on PCB layout - Mechanical data Mating cycles Center contact captivation: axial radial Coupling test torque Recommended torque min. 100 ≥ 20 N ≥ 1 Ncm max. 0.6 Nm 0.5 Nm Environmental data Temperature range Thermal shock Corrosion Vibration Shock Moisture resistance Max. soldering temperature RoHS -65°C to +165°C MIL-STD-202, Meth. 107, Cond. B MIL-STD-202, Meth. 101, Cond. B MIL-STD-202, Meth. 204, Cond. D MIL-STD-202, Meth. 213, Cond. I MIL-STD-202, Meth. 106 IEC 61760-1, +260°C for 10 sec. compliant Tooling N/A Suitable cables N/A Weight Weight 2.1 g/pce RF_35/11.05/3.1 While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date A. König 27/09/05 J_Krautenbacher 26.07.16 b00 15-1629 I_Wallner 26.07.16 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel.: +49 8684 18-0 Page email: info@rosenberger.de 2/2
32K153-400L5 价格&库存
很抱歉,暂时无法提供与“32K153-400L5”相匹配的价格&库存,您可以联系我们找货
