53BK501-K230N1
53BK501-K230N1
    ROSENBERGER
    N TYPE SURGE ARRESTER 230V
53BK501-K230N1 数据手册
Technical Data Sheet RF_35/05.10/6.0 Dieses Dokument ist urheberrechtlich geschützt Ɣ This document is protected by copyright Ɣ Rosenberger Hochfrequenztechnik GmbH & Co. KG N 50 : SURGE ARRESTER WITH 53BK501-KXXXN1 GAS CAPSULE JACK –JACK All dimensions are in mm; tolerances according to ISO 2768 m-H Interface According to IEC 61169-16, MIL-PRF-39012, CECC 22210 Documents Assembly instruction Panel piercing 53 MV-A001 B 13 Material and plating Connector parts Center contact Outer contact Body Dielectric Gasket Gasket Material CuBe Brass Brass PS Silicone NBR Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating Silver, 3-6 μm Flash white bronze over silver(e.g. Optargen®) Flash white bronze over silver(e.g. Optargen®) Tel. : +49 8684 18-0 Fax : +49 8684 18-499 Email : info@rosenberger.de Page 1/2 Technical Data Sheet N 50 : SURGE ARRESTER WITH 53BK501-KXXXN1 GAS CAPSULE JACK –JACK RF_35/05.10/6.0 Dieses Dokument ist urheberrechtlich geschützt Ɣ This document is protected by copyright Ɣ Rosenberger Hochfrequenztechnik GmbH & Co. KG Electrical data Impedance Frequency Return loss 50 : DC to 3 GHz t 30 dB @ DC to 1 GHz t 17 dB @ 1 GHz to 2 GHz t 10 dB @ 2 GHz to 3 GHz Insertion loss Insulation resistance Center contact resistance Outer contact resistance Power handling (at 20 °C, sea level, VSWR 1.0) RF-leakage Nominal impulse discharge current Rated threshold voltage DC d 0.1 x f [GHz] dB, DC to 1 GHz t 5 G: d 1 m: d 0.25 m: P=U²/R (W) t 128 dB up to 1 GHz 20 kA, Wave 8/20 PS 90V, Gas capsule order no.: 53ZB01-090 230V, Gas capsule order no.: 53ZB01-230 350V, Gas capsule order no.: 53ZB01-350 20 A AC 8 μs Ratet discharge current Attack time Mechanical data Mating cycles Center contact captivation: axial Coupling test torque Recommended torque Screw tightening torque with gas capsule t 500 t 28 N d 1.7 Nm 0.7 Nm to 1.1 Nm 9 Nm min. Environmental data Temperature range Thermal shock Corrosion resistance Vibration Shock Moisture resistance Degree of protection (mated pair) RoHS -25 °C to +85 °C MIL-STD-202, Method 107, Condition B MIL-STD-202, Method 101, Condition B MIL-STD-202, Method 204, Condition B MIL-STD-202, Method 213, Condition I MIL-STD-202, Method 106 IEC 60529, IP68 compliant Weight Weight 237 g/pce While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date Rong Fang 15/04/11 Sa. Krautenbacher 18.03.14 b00 14-0352 T. Krojer 18.03.14 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Fax : +49 8684 18-499 Email : info@rosenberger.de Page 2/2
53BK501-K230N1 价格&库存
很抱歉,暂时无法提供与“53BK501-K230N1”相匹配的价格&库存,您可以联系我们找货
