53BK565-K090N1
53BK565-K090N1
    ROSENBERGER
    N TYPE SURGE ARRESTER
53BK565-K090N1 数据手册
Technical Data Sheet RF_35/05.10/6.0 Dieses Dokument ist urheberrechtlich geschützt Ɣ This document is protected by copyright Ɣ Rosenberger Hochfrequenztechnik GmbH & Co. KG N 50 : SURGE ARRESTER 53BK565-KXXN1 JACK - JACK All dimensions are in mm; tolerances according to ISO 2768 m-H Residual Residual Order No Nom. DC Residual voltage energy spark over voltage (4kV 1.2/50μs, (4kV 1.2/50μs, (20kA 8/20 μs) voltage 2kA 8/20 μs) 2kA 8/20 μs) 53BK565-K090N1 53BK565-K230N1 53BK565-K350N1 90 V 230 V 350 V d 650 V d 650 V Power handling (20 °C, sea level, VSWR 1.0) d 1.2 mJ 1000 W Gas capsule 53ZB01-090 53ZB01-230 53ZB01-350 Interface According to IEC 61169-16, MIL-PRF-39012, CECC 22210 Documents Panel piercing Assembly instruction B 13 60 X02 Material and plating Connector parts Center contact jack side Outer contact Body Dielectric Gasket Material Spring bronze Brass Brass PTFE Silicone Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating Silver, 3-6 μm Flash white bronze over silver (e.g. Optargen®) Flash white bronze over silver (e.g. Optargen®) Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 1/2 Technical Data Sheet N 50 : SURGE ARRESTER 53BK565-KXXN1 JACK - JACK Electrical data RF_35/05.10/6.0 Dieses Dokument ist urheberrechtlich geschützt Ɣ This document is protected by copyright Ɣ Rosenberger Hochfrequenztechnik GmbH & Co. KG Impedance Frequency Return loss Insertion loss Center contact resistance Outer contact resistance RF-leakage Intermodulation 3rd order Nominal impulse discharge current 50 : 698 to 2700 MHz t 21 dB, 698 to 800 MHz t 26 dB, 800 to 960 MHz t 21 dB, 960 to 1700 MHz t 26 dB, 1700 to 2200 MHz t 24 dB, 2200 to 2500 MHz t 21 dB, 2500 to 2700 MHz d 0.1 dB d 5 m: d 5 m: t 128 dB @ DC to 1 GHz < -117 dBm @ 2 x 20 W 10 x 20 kA (8/20 μs) 1 x 30 kA (8/20 μs) Mechanical data Mating cycles Center contact captivation: axial radial Recommended torque t 500 t 28 N t 3 Ncm 0.7 Nm to 1.1 Nm Environmental data Temperature range Thermal shock Corrosion Vibration Shock Moisture resistance Degree of protection RoHS -45°C to +85°C MIL-STD-202, Meth. 107, Cond. B MIL-STD-202, Meth. 101, Cond. B MIL-STD-202, Meth. 204, Cond. B MIL-STD-202, Meth. 213, Cond. I MIL-STD-202, Meth. 106 IEC 60529, IP68 1h, 2.5 bar (mated condition) compliant Weight Weight 240 g/pce While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date M. Wimmer 26.03.12 J_Gramsamer 15.04.15 d00 15-0397 J_Krautenb. 15.04.15 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 2/2
53BK565-K090N1 价格&库存
很抱歉,暂时无法提供与“53BK565-K090N1”相匹配的价格&库存,您可以联系我们找货
