53EK565-K220N1
53EK565-K220N1
    ROSENBERGER
    N TYPE SURGE ARRESTER, FINE PROT
53EK565-K220N1 数据手册
Technical Data Sheet - DRAFT RF_35/05.10/6.0 Dieses Dokument ist urheberrechtlich geschützt Ɣ This document is protected by copyright Ɣ Rosenberger Hochfrequenztechnik GmbH & Co. KG N 50 : Surge Arrester 53EK565-K220N1 Jack – Jack (Fine protection) All dimensions are in mm; tolerances according to ISO 2768 m-H Interface According to IEC 60169-16, MIL-PRF-39012, CECC 22210 Documents Panel piercing B 13 Material and plating Connector parts Center contact Outer contact Body Dielectric Gasket Gasket Material Spring bronze Brass Brass PTFE Silicone NBR Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating Silver, 3-6 μm Flash white bronze over silver(e.g. Optargen®) Flash white bronze over silver(e.g. Optargen®) Tel. : +49 8684 18-0 Fax : +49 8684 18-499 Email : info@rosenberger.de Page 1/2 Technical Data Sheet - DRAFT N 50 : Surge Arrester 53EK565-K220N1 Jack – Jack (Fine protection) Electrical data 50 : 698 to 2500 MHz t 21 dB, 698 to 800 MHz t 26 dB, 800 to 960 MHz t 24 dB, 960 to 1700 MHz t 26 dB, 1700 to 2200 MHz t 24 dB, 2200 to 2500 MHz t 21 dB, 2500 to 2700 MHz d 0.1 dB d 5 m: d 5 m: 30 W (at 20 °C, sea level, VSWR 1.0) t 128 dB up to 1 GHz d -117 dBm @ 2 x 20 W 2A + 15 V, nom. d 40 V @ 4 kV 1.2/50 μs, 2 kA 8/20 μs RF_35/05.10/6.0 Dieses Dokument ist urheberrechtlich geschützt Ɣ This document is protected by copyright Ɣ Rosenberger Hochfrequenztechnik GmbH & Co. KG Impedance Operating frequency Return Loss Insertion loss Center contact resistance Outer contact resistance Power handling RF-leakage Intermodulation (3rd order) DC current DC voltage Resuidual voltage Mechanical data Mating cycles Coupling nut retention Center contact captivation: axial radial Coupling torque (recommended) Proof torque min. 500 t 450 N t 28 N t 3 Ncm 0.7 to 1.1 Nm max. 1.7 Nm Environmental data Temperature range Thermal shock Corrosion Vibration Shock Moisture resistance -45°C to +85°C MIL-STD-202, Meth. 107, Cond. B MIL-STD-202, Meth. 101, Cond. B MIL-STD-202, Meth. 204, Cond. B MIL-STD-202, Meth. 213, Cond. I MIL-STD-202, Meth. 106 Degree of protection RoHS IEC 60529, IP68 2.5 bar (mated condition) compliant Weight Weight 231 g/pce While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date Gramsamer Josef 25/05/10 Sa. Krautenbacher 18.03.14 300 14-0352 T. Krojer 18.03.14 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Fax : +49 8684 18-499 Email : info@rosenberger.de Page 2/2
53EK565-K220N1 价格&库存
很抱歉,暂时无法提供与“53EK565-K220N1”相匹配的价格&库存,您可以联系我们找货
