53S152-K00N5
53S152-K00N5
    ROSENBERGER
    N TYPE ADAPTER
53S152-K00N5 数据手册
TECHNICAL DATA SHEET ADAPTOR N 50 Ω PLUG – C JACK 53S152-K00N5 All dimensions are in mm; tolerances according to ISO 2768 m-H Interface According to N side: C side: IEC 60169-16, MIL-PRF-39012, CECC 22210 IEC 60169-7, MIL C-39012, VG 95240, DIN 47222 Documents N/A Material and plating RF_35/12.04/3.0 Connector parts Center contact Outer contact N side Outer contact C side Dielectric Gasket Coupling nut Material CuBe Brass Brass PTFE Silicone Brass Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating AuroDur®, gold plated Flash white bronze over silver(e.g. Optargen®) Flash white bronze over silver(e.g. Optargen®) Flash white bronze over silver(e.g. Optargen®) Tel.: +49 8684 18-0 Fax: +49 8684 18-499 email: info@rosenberger.de Page 1/2 TECHNICAL DATA SHEET ADAPTOR N 50 Ω PLUG – C JACK 53S152-K00N5 Electrical data Impedance Frequency Return loss Insertion loss Insulation resistance Center contact resistance Outer contact resistance Test voltage Working voltage Power handling (at 20 °C, sea level, VSWR 1.0) 50 Ω DC to 11 GHz ≥ 35 dB, DC to 1 GHz ≥ 28 dB, 1 to 2 GHz ≥ 18 dB, 2 to 4 GHz ≤ 0.05 dB, DC to 4 GHz ≥ 5 x103 MΩ ≤ 1 mΩ, N side ≤ 1 mΩ, C side ≤ 0.25 mΩ, N side ≤ 0.25 mΩ, C side 2500 V rms 1000 V rms 400 W @ 1 GHz Mechanical data Mating cycles Coupling nut retention Center contact captivation: axial Coupling test torque Recommended torque N side min. 500 ≥ 450 N ≥ 28 N max. 1.7 Nm 0.7 Nm to 1.1 Nm C side min. 500 N/A ≥ 28 N N/A N/A Environmental data Temperature range Thermal shock Corrosion Vibration Shock Moisture resistance 2002/95/EC (RoHS) -55°C to +155°C MIL-STD-202, Meth. MIL-STD-202, Meth. MIL-STD-202, Meth. MIL-STD-202, Meth. MIL-STD-202, Meth. compliant 107, 101, 204, 213, 106 Cond. Cond. Cond. Cond. B B B I Tooling N/A Suitable cables N/A Packing Standard Weight 1 pce in bag 39.9 g/pce RF_35/12.04/3.0 While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date Inge Mühlauer 08/06/04 Fellner A. 15.10.07 c00 07-0154 S_Kra. 15.10.07 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel.: +49 8684 18-0 Fax: +49 8684 18-499 email: info@rosenberger.de Page 2/2
53S152-K00N5 价格&库存
很抱歉,暂时无法提供与“53S152-K00N5”相匹配的价格&库存,您可以联系我们找货
53S152-K00N5
  • 10+565.7189710+73.42000
