53Z111-000N5
53Z111-000N5
    ROSENBERGER
    N TYPE SHORTING CAP
53Z111-000N5 数据手册
TECHNICAL DATA SHEET N 50 Ω SHORTING CAP PLUG 53Z111-000N5 All dimensions are in mm; tolerances according to ISO 2768 m-H Interface According to IEC 60169-16, MIL-PRF-39012, CECC 22210 Documents N/A Material and plating RF_35/11.05/3.1 Connector parts Center contact Outer contact Body Material Brass Brass Brass Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating AuroDur®, gold plated Flash white bronze over silver(e.g. Optargen®) Flash white bronze over silver(e.g. Optargen®) Tel.: +49 8684 18-0 Fax: +49 8684 18-499 email: info@rosenberger.de Page 1/2 TECHNICAL DATA SHEET N 50 Ω SHORTING CAP PLUG 53Z111-000N5 Electrical data ~0 Ω (shorted), DC Impedance Mechanical data Mating cycles Coupling nut retention Center contact captivation: axial radial Coupling test torque Recommended torque min. 500 ≥ 450 N ≥ 28 N ≥ 3 Ncm max. 1.7 Nm 0.7 Nm to 1.1 Nm Environmental data Temperature range Thermal shock Corrosion Vibration Shock Moisture resistance 2002/95/EC (RoHS) -55°C to +155°C MIL-STD-202, Meth. MIL-STD-202, Meth. MIL-STD-202, Meth. MIL-STD-202, Meth. MIL-STD-202, Meth. compliant 107, 101, 204, 213, 106 Cond. Cond. Cond. Cond. B B B I Tooling N/A Suitable cables N/A Packing Standard Weight 1 pce in bag 21.6 g/pce RF_35/11.05/3.1 While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date Inge Mühlauer 15/06/04 Fellner A. 17.10.07 e00 07-0154 S_Kra. 17.10.07 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel.: +49 8684 18-0 Fax: +49 8684 18-499 email: info@rosenberger.de Page 2/2
53Z111-000N5 价格&库存
很抱歉,暂时无法提供与“53Z111-000N5”相匹配的价格&库存,您可以联系我们找货
