Technical Data Sheet
RFB00035/12.20/6.4
Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG
SMB
59S206-400L5
Right Angle Plug PCB
All dimensions are in mm; tolerances according to ISO 2768 m-H
Interface
According to
IEC 60169-10, CECC 22130, MIL-PRF-39012
Documents
Panel piercing / PCB layout
B 30 / B 54
Material and plating
Connector parts
Center contact
Outer contact
Body
Dielectric
Material
Brass
Brass
Brass
PTFE
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.com
öffentlich | public
Plating
AuroDur®, gold plated
Gold, 0.1 µm min.
Tel. : +49 8684 18-0
Email : info@rosenberger.com
Page
1/2
SMB
59S206-400L5
RFB00035/12.20/6.4
Electrical data
Impedance
Frequency
Return loss
50
DC to 4 GHz
25 dB @ DC to 1 GHz
20 dB @ 1 GHz to 3 GHz
18 dB @ 3 GHz to 4 GHz
Insertion loss
0.1 x
f [GHz] dB
1 G
5 m
2.5 m
750 V rms
250 V rms
1.5 A DC
55 dB @ DC to 1 GHz
Insulation resistance
Center contact resistance
Outer contact resistance
Test voltage (at sea level)
Working voltage (at sea level)
Contact current
RF-leakage
- Connector only, VSWR in application depends decisive on PCB layout
Mechanical data
Mating cycles
Center contact captivation: axial
Engagement force
Disengagement force
500
10 N
63 N
8 N to 63 N
Environmental data
Temperature range
Thermal shock
Vibration
Corrosion
Moisture resistance
Max. soldering temperature
RoHS
-55 °C to +155 °C
MIL-STD-202, Method 107, Condition B
MIL-STD-202, Method 204, Condition B
MIL-STD-202, Method 101, Condition B
MIL-STD-202, Method 106
IEC 61760-1, +260 °C for 10 sec.
compliant
Tooling
N/A
Suitable cables
N/A
Weight
Weight
3.4 g/pce
While the information has been carefully compiled to the best of our knowledge, nothing is
intended as representation or warranty on our part and no statement herein shall be
construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
For the installation of the
electrotechnical equipment,
particular electrotechnical
expertise is required.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
Inge Mühlauer
07.12.04
E. Schwangler
20.01.23
f00
23-0142
S. Schier
20.01.23
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.com
öffentlich | public
Page
2/2
很抱歉,暂时无法提供与“59S206-400L5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+148.58640
- 200+59.29200
- 500+57.30480
- 1000+56.33280
