74S121-K20S3
74S121-K20S3
    ROSENBERGER
    F TYPE CALIBRATION ADAPTER
74S121-K20S3 数据手册
Technical Data Sheet F 75 Calibration Adaptor 74S121-K20S3 Plug/Jack All dimensions are in mm; tolerances according to ISO 2768 m-H Interface According to IEC 169-24 ; EIA-550 Documents Application note AN001 “Calibration Services” Material and plating Connector parts Center conductor Outer conductor Coupling nut Dielectric Material CuBe Stainless steel Stainless steel PS Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating Gold, min. 1.27 µm, over nickel Passivated Passivated Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 1/3 Technical Data Sheet F 75 Calibration Adaptor 74S121-K20S3 Plug/Jack Electrical data Frequency range Return loss DC to 4 GHz 32 dB, DC to 4 GHz Mechanical data Mating cycles Maximum torque Recommended torque Accommodate male contact diameter Gauge 500 6.78 Nm 2.00 Nm 0.76 mm to 0.86 mm 0.00 mm to 0.10 mm General standard definitions For proper operation the vector network analyzer (VNA) needs a model describing the electrical behaviour of this calibration standard. The different models, units, and terms used will depend on the VNA type and they will have to be entered into the VNA. All values are based on typical geometry and plating. Offset Zo / Impedance / Zo Offset Delay Length (electrical) / Offset Length Offset Loss Loss 75 108.740 ps 32.60 mm 1.30 G /s 0.0082 dB/ GHz Environmental data Operating temperature range1 Rated temperature range of use2 Storage temperature range + 20 °C to +26 °C 0 °C to +50 °C - 40 °C to +85 °C RoHS compliant 1 2 Temperature range over which these specification are valid. This range is underneath and above the operating temperature range, within the calibration adaptor is fully functional and could be used without damage. Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 2/3 Technical Data Sheet F 75 Calibration Adaptor 74S121-K20S3 Plug/Jack Declaration of calibration options Factory Calibration Standard delivery for this calibration standard includes a Factory Calibration. The Calibration Certificate issued reports individual calibration results, traceable to Rosenberger standards, national / international standards are not available. Model based standard definitions are reported in an Agilent/Keysight, Rohde & Schwarz and Anritsu compatible VNA format. Accredited Calibration Not available. For further, more detailed information see application note AN001 on the Rosenberger homepage. Calibration interval Recommendation 12 months Packing Standard Weight 1 pce in box 28.7 g/pce While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date Herbert Babinger 04.05.15 Markus Müller 29.08.16 f00 16-1390 Marion Striegler 29.08.16 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 3/3
74S121-K20S3 价格&库存
很抱歉,暂时无法提供与“74S121-K20S3”相匹配的价格&库存,您可以联系我们找货
