78K102-K00L5
78K102-K00L5
    ROSENBERGER
    1.6/5.6 GEN II ADAPTER
78K102-K00L5 数据手册
TECHNICAL DATA SHEET ADAPTOR 1.6/5.6 JACK - JACK 78K102-K00L5 All dimensions are in mm; tolerances according to ISO 2768 m-H Interface According to CECC 22 240 Documents Panel piercing B 27 Material and plating RF_35/06.07/5.0 Connector parts Center contact Outer contact Body Dielectric Material CuBe Brass Brass PTFE Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating AuroDur®, gold plated AuroDur®, gold plated AuroDur®, gold plated Tel.: +49 8684 18-0 Fax: +49 8684 18-499 email: info@rosenberger.de Page 1/2 TECHNICAL DATA SHEET ADAPTOR 1.6/5.6 JACK - JACK 78K102-K00L5 Electrical data 75 Ω DC to 4 GHz ≥ 30 dB, DC to 0.5 GHz ≥ 25 dB, 0.5 to 2 GHz ≥ 15 dB, 2 to 4 GHz ≤ 0.1 dB, DC to 2 GHz ≥ 10x103 MΩ ≤ 4 mΩ ≤ 2 mΩ 1000 V rms 330 V rms ≥ 90 dB up to 1 GHz (slide-on) ≥ 100 dB up to 1 GHz (screw version) Impedance Frequency Return loss Insertion loss Insulation resistance Center contact resistance Outer contact resistance Test voltage Working voltage RF-leakage Mechanical data Mating cycles Engaging and disengaging force Center contact captivation: axial Torque nut for panel mounting Coupling mechanism retention force ≥ 500 2.2 N to 12 N (screw-on, slide-on) 18 N to 50 N (quick-lock) ≥ 30 N ≤ 1 Nm ≥ 300 N (screw version, quick-lock) Environmental data Temperature range Climatic class -40°C to +85°C IEC 60068-2-1 40/85/21 IEC 60068-2-2 IEC 60068-2-3 IEC 60068-2-6 10 Hz to 2000 Hz, 100m/s² compliant Vibration 2002/95/EC (RoHS) Tooling N/A Suitable cables N/A Packing Standard Weight 1 pce in bag 6.3 g/pce RF_35/06.07/5.0 While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date Inge Mühlauer 24/08/04 Chr. Entsfellner 04/02/08 d00 08-0091 Rong Fang 04/02/08 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel.: +49 8684 18-0 Fax: +49 8684 18-499 email: info@rosenberger.de Page 2/2
78K102-K00L5 价格&库存
很抱歉,暂时无法提供与“78K102-K00L5”相匹配的价格&库存,您可以联系我们找货
