88K171-K00L5
88K171-K00L5
    ROSENBERGER
    1.6/5.6 GEN III ADAPTER
88K171-K00L5 数据手册
TECHNICAL DATA SHEET ADAPTOR 1.6/5.6 III JACK – BNC 75 Ω JACK 88K171-K00L5 All dimensions are in mm; tolerances according to ISO 2768 m-H Interface BNC side 1.6/5.6 side Compatible to According to IEC 60169-8, MIL-PRF-39012, CECC 22120 CECC 22 240 Documents Panel piercing B 27 Material and plating RF_35/12.04/3.0 Connector parts Center contact Outer contact 1.6/5.6 side Outer contact BNC side Dielectric 1.6/5.6 side Dielectric BNC side Material Beryllium copper Brass Brass LCP PTFE Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Plating AuroDur, gold plated AuroDur, gold plated Nickel, 2.5-5 µm Tel.: +49 8684 18-0 Fax: +49 8684 18-499 email: info@rosenberger.de Page 1/2 TECHNICAL DATA SHEET ADAPTOR 1.6/5.6 III JACK – BNC 75 Ω JACK 88K171-K00L5 Electrical data 75 Ω DC to 4 GHz ≥ 30 dB, DC to 0.5 GHz ≥ 25 dB, 0.5 to 1 GHz ≥ 20 dB, 1 to 2 GHz ≤ 0.1 dB, DC to 2 GHz ≥ 10x103 MΩ ≤ 1.5 mΩ, BNC side; ≤ 4 mΩ, 1.6/5.6 side ≤ 1 mΩ, BNC side; ≤ 2 mΩ, 1.6/5.6 side 1000 V rms 330 V rms ≥ 90 dB up to 1 GHz (slide-on) ≥ 100 dB up to 1 GHz (screw version) Impedance Frequency Return loss Insertion loss Insulation resistance Center contact resistance Outer contact resistance Test voltage Working voltage RF-leakage Mechanical data Mating cycles Center contact captivation: axial Engaging and disengaging force BNC side min. 500 ≥ 30 N ≤ 20 N 1.6/5.6 side min. 500 ≥ 30 N 2.2 N to 12 N (screw-on, slide-on) 18 N to 50 N (quick-lock) Environmental data Temperature range Climatic class -40°C to +85°C IEC 60068-2-1 40/85/21 IEC 60068-2-2 IEC 60068-2-3 IEC 60068-2-6 10 Hz to 2000 Hz, 100m/s² compliant Vibration 2002/95/EC (RoHS) Tooling N/A Suitable cables N/A Packing Standard Weight 1 pce in bag 12.4 g/pce RF_35/12.04/3.0 While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date Inge Mühlauer 30/08/04 A. König 10/07/07 c00 07-0154 S. Huber-Siegl 10/07/07 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel.: +49 8684 18-0 Fax: +49 8684 18-499 email: info@rosenberger.de Page 2/2
88K171-K00L5 价格&库存
很抱歉,暂时无法提供与“88K171-K00L5”相匹配的价格&库存,您可以联系我们找货
