Technical Data Sheet - Draft
RF_35/09.14/6.2
Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG
EBC
EBCS11D-S09N5
Adaptor
All dimensions are in mm; tolerances acc. to ISO 2768 m-H
Interface
According to
Rosenberger EBC™
Documents
Application note
EBC
Material and plating
Connector parts
Center contact
Outer contact
Dielectric
Material
Cu
Brass
PTFE
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Plating
AuroDur®, gold plated
Flash white bronze over silver(e.g. Optargen®)
Tel. : +49 8684 18-0
Email : info@rosenberger.de
Page
1/2
EBC
EBCS11D-S09N5
Adaptor
RF_35/09.14/6.2
Electrical data
Impedance
Frequency
Return loss
50
DC to 8 GHz
26 dB @ DC to 6 GHz 1)
Insertion loss
0.05 x
Insulation resistance
Center contact resistance
Outer contact resistance
Test voltage (at sea level)
Working voltage (at sea level)
Power handling (sea level, VSWR 1.0)
Contact Current
Screening attenuation - Interface
Intermodulation (3rd order)
5 G
10 m
5 m
500 V rms
335 V rms
100 W @ 3.5 GHz @ 105°C 2)
2A DC
50 dB up to 4 GHz
160 dBc (2 x 43 dBm)
f [GHz] dB
1) Dependent on axial misalignment
2) Power value is dominated by the application
Mechanical data
50
5N
Mating cycles
Center contact captivation
Engagement force
-Limited detent
-smooth bore
Disengagement force
-Limited detent
-smooth bore
Working range
Radial misalignment
Pitch
35N (typ.30N)
12N
12N
5N
1.6 mm (± 0.8 mm)
max. 4°
6.9 mm
Environmental data
Temperature range
Thermal shock
Climatic category
Moisture resistance
Vibration
Shock
RoHS
-55 °C to +105 °C
MIL-STD-202, Method 107, Condition B
IEC 61169-1, Sub-clause 9.4.5
MIL-STD-202, Method 106
MIL-STD-202, Method 204, Condition B
MIL-STD-202, Method 213, Condition A
compliant
Weight
Weight
0.55g/pc (tbd)
While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on
our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our
products, we reserve the right to make changes judged to be necessary.
Draft
Date
Approved
Date
Rev.
Engineering change number
Name
Date
M. Schmid
16.07.19
M_Schmid
17.09.19
200
19-1632
T_Stadler
17.09.19
P.O.Box 1260
D-84526 Tittmoning
Germany
www.rosenberger.de
Page
2/2
很抱歉,暂时无法提供与“EBCS11D-S09B1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+143.98560
- 200+55.72800
- 500+53.76240
- 1000+52.80120
