P5440050M4AA2
P5440050M4AA2
    ROSENBERGER
    光纤电缆 LC 双工 至 LC 双工 50/125 16.4'(5.0m)
P5440050M4AA2 数据手册
TCH-DS -PC-0014 Technical Data Sheet Fiber Optic Cable Patch Cords – Made in USA PXXXXXXXXXXXX Scope ⚫ This data sheet represents products which Rosenberger offers for sale Made in USA from our factory in Akron Pennsylvania. ⚫ ◼ These products are a sub-set of many other cable/connector variations produced by Rosenberger. Please see our detailed Product Information catalogs or contact your sales representative for more information Application ⚫ ⚫ ⚫ ⚫ Channel to channel connection of fiber optic lines installed within distribution panels Connection of peripheral devices with a fiber optic interface On-site splicing with bulk cable Other scenarios where fiber connection is required ● This document is protected by copyright ● Rosenberger North America Features/Benefits ⚫ ⚫ ⚫ ⚫ ⚫ ⚫ Outer sheath made plenum rated material 100% performance testing Providing test report for 3D geometric characteristics of connector end-face as required Optical test report available on request Separately packed in plastic bag, including serial number and attenuation data Made in USA Profile/Outline Rosenberger North America 309 Colonial Dr. Akron, Pa 17501 Tel: +1 (717) 859-8900 Fax: +1 (717) 859-7044 Email : info@rosenbergerna.com Web : https://www.rosenberger.com/us_en Page 1/4 TCH-DS -PC-0014 Technical Data Sheet Fiber Optic Cable Patch Cords – Made in USA PXXXXXXXXXXXX Construction/Dimension/Material ⚫ ⚫ ⚫ ⚫ Fiber types: Single-mode 9/125um, Multi-mode 62.5/125um and 50/125um Connecter variants: Simplex and duplex Cable options: 2.0mm simplex/duplex cable Other cable adoptions upon request Delivery form: Single item in plastic bag One product ID label with measurement values per patchcord Serial number label on patchcord Standards ● This document is protected by copyright ● Rosenberger North America ⚫ ⚫ ⚫ ⚫ LC Comply with IEC 61754-20 SC Comply with TIA/EIA 568, IEC 874-10 The insertion loss test acc. to IEC 61300-3-4 The return loss test acc. to IEC 61300-3-6 Fiber Type International Standards Attenuation (dB/km) Wavelengths (nm) OS2 9/125μm ITU G.652.D, G.657.A1 0.36/0.22 1310/1550 OM1 62.5/125μm ITU G.651.1 TIA/EIA 492AAAA-B IEC 60793-2-10 type A1b 3.0/1.0 850/1300 1G Ethernet Distance 280m at 850nm OM3 50/125μm ITU 651.1 TIA/EIA 492AAAC-B IEC 60793-2-10 Type A1a.2 3.0/1.0 850/1300 10G Ethernet Distance 300m at 850nm OM4 50/125μm ITU 651.1 TIA/EIA 492AAAD IEC 60793-2-10 Type A1a.3 850/1300 10G Ethernet Distance 550m at 850nm 40G Ethernet Distance 150m at 850nm 100G Ethernet Distance 100m at 850nm ⚫ Applications 1G/10G/40G/100G/400G Ethernet connection 100/1000BASE-SX transceivers. Fast Ethernet, gigabit Ethernet and fiber channel applications 10G SR, 10G LRM, SFP+ transceivers for 10G/40G/100G Ethernet applications 40G BIDI SR, 10G SR, QSFP+, SFP+ transceivers, etc. for 10G/40G/100G Ethernet applications Connector Insertion Loss & Return loss Single-mode SC; LC Multi-mode SC; LC ⚫ 3.0/1.0 Transmission Characteristics Ultra (UPC) Angle(APC) IL Typical 0.20 dB 0.20 dB IL Maximum 0.40 dB 0.40 dB Ultra (UPC) 0.15 dB 0.40 dB RL Typical -55 dB -65dB RL Minimum -45dB -60dB Test Reference Cord Connector Insertion Loss & Return loss Single-mode SC; LC Multi-mode SC; LC Ultra (UPC) Angle(APC) IL Typical 0.080 dB 0.080 dB IL Maximum 0.10 dB 0.10 dB RL Typical -55 dB -65dB RL Minimum -50dB -60dB Ultra (UPC) 0.080 dB 0.10 dB -50dB -35dB Rosenberger North America 309 Colonial Dr. Akron, Pa 17501 Tel: +1 (717) 859-8900 Fax: +1 (717) 859-7044 Email : info@rosenbergerna.com Web : https://www.rosenberger.com/us_en Page 2/4 TCH-DS -PC-0014 Technical Data Sheet Fiber Optic Cable Patch Cords – Made in USA PXXXXXXXXXXXX Mechanical Data Minimum bending radius cable Installation Operation 50 mm 30 mm Max. tensile strength cable Installation Permanent Crush resistance 440 N 132 N 350 N / 100 mm Tensile test for connector Max.70N/120s Tensile force between cable and connector 68 N (except for cable diameter of < 1 mm). ● This document is protected by copyright ● Rosenberger North America Environmental Data Temperature range operation Temperature range storage Temperature range installation °C 2011/65/EU (RoHS) -10 °C to +70 °C -10°C to +70 °C 0 °C to +60 Compliant Flammability UL Plenum Compliant Rosenberger North America 309 Colonial Dr. Akron, Pa 17501 Tel: +1 (717) 859-8900 Fax: +1 (717) 859-7044 Email : info@rosenbergerna.com Web : https://www.rosenberger.com/us_en Page 3/4 TCH-DS -PC-0014 Technical Data Sheet Fiber Optic Cable Patch Cords – Made in USA PXXXXXXXXXXXX Ordering Information Rosenberger patchcords and pigtails are ordered using 12 digits: PXXXXXXXXXXXX Cord type ● This document is protected by copyright ● Rosenberger North America P= Patch Cord Standard Fiber Fiber 1 = Simplex OFNP 3 = Duplex (Zip) OFNP 5 = Duplex (Round) OFNP 1= Singlemode 2 = 62.5 / OM1 3 = 50 LO / OM3 4 = 50 LO / OM4 Connector s Left Length XXXX 1 = ST M= Meter 0010=1 m F = Feet 2 = SC Connectors Right UofM Polarity Jacket color Cable Diameter (mm) 0 = Stub A = A to B E = Erika Violet 1 = 1.6 1 = ST B = A to A A = Aqua 2 = 2.0 3 = 3.0 3 = FC 2 = SC O = Orange 4 = LC H= LC/APC J= SC/APC K= FC/APC 3 = FC Y = Yellow 4 = LC I = Ivory H = LC/APC J = SC/APC K = FC/APC *Note the last length digit represents decimal. For example the 0015 of P3140015M4AY2 means 1.5m *SC uniboot is not available While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date D. Keller 5/29/20 Naomi 5/29/20 100 ECN 20-e000; Preliminary D. Keller 5/29/20 Rosenberger North America 309 Colonial Dr. Akron, Pa 17501 Tel: +1 (717) 859-8900 Fax: +1 (717) 859-7044 Email : info@rosenbergerna.com Web : https://www.rosenberger.com/us_en Page 4/4
P5440050M4AA2 价格&库存
很抱歉,暂时无法提供与“P5440050M4AA2”相匹配的价格&库存,您可以联系我们找货
P5440050M4AA2
  • 1+386.930241+50.15353
