L70-324-140
L70-324-140
    ROSENBERGER
    同轴电缆组件 1.35mm 至 1.35mm UT-047-TP 5.512"(140.00mm)
L70-324-140 数据手册
Technical Data Sheet Cable assembly L70-324-XXX RF_35/09.14/6.2 Dieses Dokument ist urheberrechtlich geschützt ● This document is protected by copyright ● Rosenberger Hochfrequenztechnik GmbH & Co. KG RPC-1.35 Plug – UT-047-TP – RPC-1.35 Plug All dimensions are in mm; tolerances: ± 3mm for A ≤ 300 mm; ± 1% for A > 300 mm *) If length “A” ≤ 90 mm marking is mount centric ± 5mm Available variants Type max. Insertion loss L70-324-XXX dB ≤ 0.0022 ∗ f[GHz] mm Marking ROSENBERGER L70-324-XXX Weight (g) / pce YYYY-WW 0.0057 g ∗ A[mm] + 4.4g mm XXX – length in mm = A Maximum possible length = 2000mm WW – week YYYY – year Note: Weight: First constant = Cable weight per mm; Second Constant = Connector left and Connector right weight per pce Assembly parts Connector left Connector right Cable Armour RPC-1.35 Plug RPC-1.35 Plug UT-047-TP none Electrical data 50  DC to 90 GHz, typical up to 109 GHz  17 dB, DC to 26.5 GHz  14 dB, 26.5 to 50 GHz  12 dB, 50 to 90 GHz, typical up to 109 GHz see table available variants Impedance Frequency Return loss1 Insertion loss1 1 Return Loss and Insertion Loss includes the measurement adaptor Mechanical data Minimum bend radius: Single Mating cycles Maximum torque Recommended torque 20.0 mm ≤ 50 1.65 Nm 0.90 Nm Environmental data Temperature range RoHS - 40 °C to +125 °C compliant While the information has been carefully compiled to the best of our knowledge, nothing is intended as representation or warranty on our part and no statement herein shall be construed as recommendation to infringe existing patents. In the effort to improve our products, we reserve the right to make changes judged to be necessary. Draft Date Approved Date Rev. Engineering change number Name Date Marion Striegler 15.12.17 Ronny Mark 04.11.19 d00 19-2041 Marion Striegler 04.11.19 Rosenberger Hochfrequenztechnik GmbH & Co. KG P.O.Box 1260 D-84526 Tittmoning Germany www.rosenberger.de Tel. : +49 8684 18-0 Email : info@rosenberger.de Page 1/1
L70-324-140 价格&库存
很抱歉,暂时无法提供与“L70-324-140”相匹配的价格&库存,您可以联系我们找货
