185-J-P-EP-ST-CMM-2
185-J-P-EP-ST-CMM-2
    SAMTEC(申泰)
    CONN 1.85MM JACK COMP MNT
185-J-P-EP-ST-CMM-2 数据手册
REVISION A DESIGNED AND DIMENSIONED IN INCHES[MILLIMETERS] ALL DIMENSIONS REFERENCE EXCEPT AS SHOWN 185-J-P-EP-ST-CMM-X DO NOT SCALE FROM THIS PRINT GENDER -J: JACK TERMINATION -CMM: COMPRESSION MOUNT MICROSTRIP TYPE -P: PCB .428 10.87 .308 7.82 .003 0.08 (GROUNDING RING HEIGHT) ORIENTATION -ST: STRAIGHT FINISH -EP: 50µ" EXTRA HEAVY GOLD CENTER CONTACT, PASSIVATED OUTER CONTACT REF PLANE OPTION -1: OPTION 1 (WITHOUT SCREWS) -2: OPTION 2 (WITH SCREWS) .230 5.84 .0155 0.39 (CENTER CONTACT) CL .003 0.06 M7 X 0.75 - 6g .120 3.05 .222 5.64 DETAIL 'A' SCALE 12 : 1 .199 5.04 .065 1.65 0-80 UNF-2B THRU (2 PLCS) (SEE NOTE 1) 'A' .018 0.46 (SIGNAL PAD) .063 1.60 THRU HOLE (2 PLCS) .045 1.14 CL .282 7.16 .282 7.16 .023 0.59 (COPLANAR GROUND WIDTH) R.026 0.66 (ANTI PAD) .007 0.19 (SIGNAL TRACE) R.092 2.33 .207 5.25 GROUND PAD .141 3.58 FIG 1 185-J-P-EP-ST-CMM-X SHOWN NOTES: R.026 0.66 (GROUNDING RING INSIDE DIAMETER) R.088 2.22 (GROUNDING RING OUTSIDE DIAMETER) 1. RECOMMENDED TORQUE 0.5~0.8 INCH-POUNDS. 2. THIS IS A GENERAL FOOTPRINT AND IS NOT OPTIMIZED FOR ELECTRICAL PERFORMANCE, CONTACT SIG@SAMTEC.COM FOR ASSISTANCE WITH ELECTRICAL LAYOUT. RECOMMENDED PCB LAYOUT .400 10.16 (SEE NOTE 2) * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. MATERIAL: DO NOT SCALE DRAWING SHEET SCALE: 6:1 BODY, BUSHING & SCREW: STAINLESS STEEL SOCKET: COPPER ALLOY c:\enterprisevault\DWG\MISC\MKTG\185-J-P-EP-ST-CMM-X-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 1.85MM ST JACK FOR COMPRESSION MOUNT MICROSTRIP DWG. NO. 185-J-P-EP-ST-CMM-X BY: SHERRY W 5/21/2020 SHEET 1 OF 1
185-J-P-EP-ST-CMM-2 价格&库存
很抱歉,暂时无法提供与“185-J-P-EP-ST-CMM-2”相匹配的价格&库存,您可以联系我们找货
