240-J-P-EP-ST-CMM-1
240-J-P-EP-ST-CMM-1
    SAMTEC(申泰)
    CONN 2.40MM JACK COMP MNT
240-J-P-EP-ST-CMM-1 数据手册
REVISION A 240-J-P-EP-ST-CMM-X DESIGNED AND DIMENSIONED IN INCHES[MILLIMETERS] ALL DIMENSIONS REFERENCE EXCEPT AS SHOWN OPTION -1: OPTION 1 (WITHOUT SCREWS) -2: OPTION 2 (WITH SCREWS) GENDER -J: JACK TERMINATION -CMM: COMPRESSION MOUNT MICROSTRIP TYPE -P: PCB .428 10.87 ORIENTATION -ST: STRAIGHT FINISH -EP: 50µ" EXTRA HEAVY GOLD CENTER CONTACT, PASSIVATED OUTER CONTACT REF PLANE .308 7.82 .003 0.08 (GROUNDING RING HEIGHT) .230 5.84 CL .0155 0.39 (CENTER CONTACT) .002 0.04 .222 5.64 M7 X 0.75 - 6g .120 3.05 .199 5.04 .065 1.65 0-80 UNF-2B THRU (2 PLCS) (SEE NOTE 1) DETAIL 'A' SCALE 12 : 1 'A' .018 0.46 (SIGNAL PAD) .063 1.60 THRU HOLE (2 PLCS) .045 1.14 CL .282 7.16 .282 7.16 .023 0.59 (COPLANAR GROUND WIDTH) R.026 0.66 (ANTI PAD) .007 0.19 (SIGNAL TRACE) R.092 2.33 .207 5.25 FIG 1 240-J-P-EP-ST-CMM-X SHOWN R.026 0.66 (GROUNDING RING INSIDE DIAMETER) RECOMMENDED PCB LAYOUT .400 10.16 (SEE NOTE 2) * R.088 2.22 (GROUNDING RING OUTSIDE DIAMETER) NOTES: 1. RECOMMENDED TORQUE 0.5~0.8 INCH-POUNDS. 2. THIS IS A GENERAL FOOTPRINT AND IS NOT OPTIMIZED FOR ELECTRICAL PERFORMANCE, CONTACT SIG@SAMTEC.COM FOR ASSISTANCE WITH ELECTRICAL LAYOUT. GROUND PAD .141 3.58 PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING MATERIAL: SHEET SCALE: 6:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: 2.40MM ST JACK FOR COMPRESSION MOUNT MICROSTRIP DWG. NO. BODY, BUSHING & SCREW: STAINLESS STEEL SOCKET: COPPER ALLOY F:\DWG\SW\Exisprod\Assembly\Rf\240\240-J-P-XX-ST-CMM-X\240-J-P-EP-ST-CMM-X.SLDDRW 240-J-P-EP-ST-CMM-X BY: SHERRY W 2/24/2019 SHEET 1 OF 1
240-J-P-EP-ST-CMM-1 价格&库存
很抱歉,暂时无法提供与“240-J-P-EP-ST-CMM-1”相匹配的价格&库存,您可以联系我们找货
