REVISION
F
C2-B-DC
1.2313 REF
({50 POS x .01969} + .2468)
.055 x 45 REF (TYP)
1.191 REF
100
02
NOTES:
.245 REF
1. 50 POS, CONTACT AREA NOT AVAILABLE AS STANDARD.
2. ADD KAPTON PAD AND PACKAGE IN TAPE & REEL.
3. C REPRESENTS A CRITICAL DIMENSION.
4. MAXIMUM BURR ALLOWANCE: .0015
5. MINIMUM PUSHOUT FORCE: .5 OZ.
6. MAXIMUM ALLOWABLE BOW: .002
INCH/INCH AFTER ASSEMBLY.
7. HOLES ARE FOR OPTIONAL AGILENT SHROUD
NOT SUPPLIED BY SAMTEC.
8. PARTS TO BE PACKAGED IN TAPE AND REEL.
.285 REF
99
01
.325
.006 REF (TYP)
3
.453±.020
2
1
"A"
F
+.0030
.1280 - .0010
.120
.0040
"A"
.035 REF (TYP)
.2950
.0295 REF (TYP)
SECTION "A"-"A"
1.1863 REF
1.18620
({50 POS X .01969} + .2017)
.0340
POSITION 1
.0078
02
.0895
1.732 44.00
REF
100
.0197
.0110
.1480
.630 16.00 REF
.9647
({50 POS - 1} X .01969)
.1110
.0410
C1-B,I-DC
.0430
TYP (2)
"B"
TAPE & REEL VIEW
"B"
4
.3150
.1020
(POCKET NOT DETAILED)
99
01
USER DIRECTION OF UNREELING
1.2550
.0360
TYP (4)
RECOMMENDED P.C. BOARD LAYOUT
SECTION "B"-"B"
UNLESS OTHERWISE SPECIFIED,
DIMENSIONS ARE IN INCHES.
TOLERANCES ARE:
DECIMALS
F
ITEM NO.
PART NUMBER
QUANTITY
MATERIAL
1
BSH-050-01-D-A
1.0000
VECTRA E130i, COLOR: BLACK
2
ASP-137228-04-P-L
100.00
PHOS BRONZE, 510 SPRING TEMPER
3
K-DOT-.325-.450-.005
1.0000
POLYIMIDE FILM
4
CT-ASP717MS
1.0000
CONDUCTIVE POLYMER
.XX: .01
.XXX: .005
.XXXX: .0020
ANGLES
2
PROPRIETARY NOTE
THIS DOCUMENT CONTAINS INFORMATION
CONFIDENTIAL AND PROPRIETARY TO
SAMTEC, INC. AND SHALL NOT BE REPRODUCED
OR TRANSFERRED TO OTHER DOCUMENTS OR
DISCLOSED TO OTHERS OR USED FOR ANY
PURPOSE OTHER THAN THAT WHICH IT WAS
OBTAINED WITHOUT THE EXPRESSED WRITTEN
CONSENT OF SAMTEC, INC.
DO NOT SCALE DRAWING
SHEET SCALE: 3:1
PLATING:
CONTACT AREA: .000010 MIN GOLD OVER .000050 NICKEL
REMAINDER: .000003 MIN GOLD OVER .000050 NICKEL
F:\DWG\SW\ASP\65000\ASP-65067-01-K-TR.SLDDRW
520 PARK EAST BLVD, NEW ALBANY, IN 47150
PHONE: 812-944-6733
FAX: 812-948-5047
e-Mail info@SAMTEC.com
code 55322
DESCRIPTION:
.5mm DOUBLE ROW SOCKET ASSEMBLY
DWG. NO.
BY:
ASP-65067-01-K-TR
BRYANT
06/19/03
SHEET 1 OF 1
很抱歉,暂时无法提供与“ASP-65067-01-K-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+43.61606500+5.64017
- 1000+42.044991000+5.43700
- 国内价格 香港价格
- 1+74.448841+9.62727
- 10+63.2410810+8.17795
- 25+59.2811225+7.66587
- 50+56.4506650+7.29986
- 100+53.75513100+6.95129
- 250+51.46322250+6.65491
