F-217 SUPPLEMENT
HDMR–19–01–S–SM–PF
HDMR–29–01–S–SM
HDMR–19–02–S–SM
HDMR SERIES
HIGH-SPEED I/O RECEPTACLES
Meets Digital Display
Working Group Single
Monitor Interface
Specifications
SPECIFICATIONS
For complete specifications and
recommended PCB layouts
see www.samtec.com?HDMR
Insulator Material:
High Temperature
Thermoplastic
Contact Material:
Copper Alloy
Shell Material:
Steel
Operating Temp Range:
-25 °C to +85 °C
Plating:
Gold on Contacts, Nickel on
Shell and Tin on Tails
Current Rating:
1.3 A per pin
(6 adjacent pins powered)
Voltage Rating:
40 VAC
Contact Resistance:
30 mW
Minimum Cycles:
100
Lead-Free Solderable:
Yes
RoHS Compliant:
Yes
Hot
Pluggable
Selectively
Plated
• Panel flange option
NO. OF
POSITIONS
HDMR
–29
= Surface
Mount
Ground Tails
(-19 only)
A
(2.20)
.087
(4.55)
.179
–01
–19
–29
A
(4.60)
.181
–19–01–PF
TAIL
OPTION
–S
= Surface Mount
(Signal Leads)
(1.20)
.047
(2.00)
.079
OPTIONS
–SM
= 30 µ" (0.76 µm)
Gold on Mating Area,
Tin on Tails
01
(6.18)
.243
(15.00)
.591
(22.30)
.878
(9.98)
.393
(0.50)
.020
–02
Through-hole
or Surface Mount
(19 only)
Ground tails
Surface Mount
or Through-hole
Signal Leads
PLATING
–01
= Through-hole
Ground Tails
= 29 Positions / Mates with
HPXXX 8 Pairs
NO. OF
POSITIONS
LEAD
STYLE
–19
= 19 Positions / Mates with
HPXXX 5 Pairs
Note: Some lengths, styles
and options are non-standard,
non-returnable.
19 or 29
Positions
• Locking option
OTHER
SOLUTIONS
HDMP is an Edge Mount plug
that mates to HDMR receptacles.
Call Samtec for HDMP
Series specifications.
Optional Panel Flange
(19 position only)
(4.55)
.179
(8.00) 02
.315
(17.20)
.677
–TH
= Through-hole
(Only available on
HDMR–19–01–X–
TH–PF–L)
(1.60)
.062
–02
(Leave Blank for
no Panel Flange)
–PF
= Panel Flange
–L
= Locking Option
(Only available on
HDMR–19–01–X–
TH–PF–L)
(6.18)
.243
(1.20)
.047
(0.76)
.030
(7.50)
.295
(16.05)
.632
(5.96)
.235
(0.35)
.014
(7.20)
.283
(0.50)
.020
(2.80)
.110
(4.60) .181
(9.00)
.354
–19–01–PF–L
WWW.SAMTEC.COM
Due to technical progress, all designs, specifications and components are subject to change without notice.
–19–02–PF
(5.96)
.235
很抱歉,暂时无法提供与“HDMR-19-01-F-SM-TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 250+19.27306
- 1000+16.16567
- 2000+15.63367
- 5000+14.12229
- 6500+12.52628
- 17500+11.89755
- 国内价格 香港价格
- 250+28.03035250+3.62472
- 500+24.91474500+3.22182
- 1250+24.839731250+3.21212
- 国内价格 香港价格
- 1+46.025051+5.95168
- 10+39.0920310+5.05515
- 25+36.6387125+4.73790
- 50+34.8892250+4.51166
- 100+33.22328100+4.29623
