CR-V3
CR-V3
    FDK
    BATTERY LITHIUM 3V CR-V3
CR-V3 数据手册
Cell Type CR-V3 Specifications H W Nominal Capacity*1 Nominal Voltage Standard Charge/Discharge Current Continuous *2 Max. Discharge Current Pulse*3 Temperature Range Weight 3300mAh 3V 20mA 3500mA 7000mA -40℃~60℃ 38g 29.0mm 14.5mm 52.0mm L W H Dimensions *1 Nominal capacity is determined to an end voltage of 2.0V when the battery is allowed to discharge at a standard current level at 23oC. L *2 Current value is determined to be the level at which 50% of the nominal capacity is obtained with an end voltage of 2.0V at 23 oC. *3 Current value for obtaining 1.0V cell voltage when pulse is applied for 15seconds at 50% discharge depth at 23 oC. Typical Characteristics Pulse Discharge Characteristics of CR-V3 Discharge Characteristics of CR-V3 3.5 3.5 Pulse: 1.2A*3s on/7s off Initial Load: 4Watt Initial 3.0 Cell Voltage(V) Cell Voltage(V) 3.0 2.5 -10 oC 60 oC 23 oC 2.0 -20 oC 1.5 2.5 23 oC 2.0 0oC 1.5 1.0 1.0 0 500 1000 1500 2000 2500 3000 3500 0 4000 20 Number 0f Cycles 40 60 80 100 Discharge Characteristics of CR-V3 3.5 Load: 2Watt Initial Load: 3Watt Initial 3.0 Cell Voltage(V) 3.0 Cell Voltage(V) 140 Discharge Characteristics of CR-V3 3.5 2.5 23 oC 2.0 0 oC 1.5 1.0 120 Duration(minute) 2.5 23 oC 2.0 0oC 1.5 1.0 0 20 40 60 80 100 120 Duration(minute) 140 160 180 200 0 50 100 150 Duration(minute) 200 250 300
CR-V3 价格&库存
很抱歉,暂时无法提供与“CR-V3”相匹配的价格&库存,您可以联系我们找货
