FN2520-20-103-C1111
FN2520-20-103-C1111
    SCHAFFNER(夏弗纳)
    Single Phase EMC/EMI 线路滤波器 20 A 277VAC DC ~ 60Hz 两级 端接块
FN2520-20-103-C1111 数据手册
DATA SHEET Very High Performance Single-Phase Filters FN2520 Low Profile - High performance, EMC/EMI filter Excellent EMC filter for robotics, datacenters and a variety of other applications Approvals & Compliances Available terminals: Fast-on, wire leads, bolt and clamps Voltage rating up to 277 VAC / 400 VDC Fits within 1 height unit (HU) of a 19" rack application 50°C operating temperature 2-stage filter performance Features and Benefits FN2520 series fits perfectly within 1HU height for rack mount applications The filters are built to perform perfectly in datacenter and audio video equipment The shape allows convenient and space-saving installation Fulfills the requirements in IEC/EN 62040-1 Uninterruptible power systems (UPS) Performance indicators high standard FN2500 very high FN2520 Rated current [A] 10 32 Fulfills the requirements in IEC 62368-1 - Audio/ Video, Information and Communication Technology Equipment Fulfills the requirements in IEC/EN 60335-1 Household and similar appliances Typical Applications Datacenter (at 400 VDC) Building technology with DC power distribution Robotics, collaborative robots, autonomous machines Audio and video equipment Technical Specifications * UPS - Uninterruptible power supplies Rated operating voltage 277 VAC / 400 VDC (CQC: 250 VAC / 250 VDC) Operating frequency DC to 60 Hz Rated currents 10 to 32 A @ 50°C Overload capability 1.5 x rated current for 1 minute once per hour Cooling Natural cooling AN Climatic category FN2500: 40/100/21 acc. IEC60068-1 Flammability corresponding to Plastic material: UL 94 V0 Laces for -07 version: UL 94 VW1 Surge withstand 2 kV Ph-Ph / 4 kV Ph-PE (Level 4) High potential test voltage P(DC+) –> N(DC-) 1500 VDC for 2 sec* P(DC+)/N(DC-) –> PE 2500 VDC for 2 sec* Altitude Derating above 2000 m Certified to UL/IEC 60939-3, CSA 22.2 No. 8-13, GB/T 15287 MTBF > 300,000 h Protection category IP00 / IP20 for -103 terminals Pollution degree 2 acc. IEC 60664-1 Vibration and shock 3M12 acc. IEC 60721-3-3 Overvoltage category II acc. IEC 60664-1 Temperature range (operation and storage) FN2500: -40°C to +100°C (with derating >50°C) FN2520: -40°C to +85°C (with derating >50°C) High potential test voltage: Repetition with max. 80% of specified values Typical electrical schematic 1 L1 L2 1 2 2 2 Very High Performance Single-Phase Filters Schaffner Group DATA SHEET 27. Sep 2022 Filter Selection Table Filter Rated current Leakage current* @ 50°C (@ 40°C) @ 277 VAC/50 Hz Power Inductance** loss Capacitance** Resistance** @ 25°C L1 L2 Cx1 Cx2 Cy1 Cy2 R Weight max**** Connections*** line side/load side (@ 120 VAC/60 Hz) [A] [mA] [W] [mH] [mH] [μF] [μF] [nF] [nF] [kΩ] [kg] FN2520-10-yyC1111 10 (11) 0.82 (0.43) 8.0 8.3 8.3 1 0.47 4.7 4.7 680 -05 -07 -08 -103 0.4 FN2520-15-yyC1111 15 (17) 0.82 (0.43) 9.0 4.0 4.0 1 0.47 4.7 4.7 680 -05 -07 -08 -103 0.4 FN2520-20-yyC1111 20 (22) 0.82 (0.43) 8.4 2.4 2.4 1 0.47 4.7 4.7 680 -05 -07 -08 -103 0.5 FN2520-25-yyC1111 25 (27) 0.82 (0.43) 11.0 1.5 1.5 1 0.47 4.7 4.7 680 n.a -07 -08 -103 0.5 FN2520-32-yyC1111 32 (35) 0.82 (0.43) 13.2 0.9 0.9 1 0.47 4.7 4.7 680 n.a -07 -08 -103 0.4 Two-stage * Maximum leakage current under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage current could reach twice this level. ** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10%. *** Standard parts have same input and output connections. For combinations, please contact your sales representative. **** Weight depending on choice of connectors. Product selector FN2520-xx-yy-C1111 yy – Line / load terminal types 05: 07: 08: 103: fast-on 6.3 x 0.8 mm (up to 20 A only) wire leads M4 screw push-in terminal xx – Rated current 10-32: 10 A – 32 A 3 Very High Performance Single-Phase Filters Schaffner Group DATA SHEET 27. Sep 2022 Typical Filter Attenuation Per CISPR 17: symmetrical 50 Ω/50 Ω -> Differential Mode (DM); asymmetrical 50 Ω/50 Ω -> Common Mode (CM) FN2520 - Two-stage filter Hz Hz FN2520-15-yy-C1111 FN2520-10-yy-C1111 FN2520-25-yy-C1111 FN2520-20-yy-C1111 Hz Hz FN2520-32-yy-C1111 Hz 4 Very High Performance Single-Phase Filters Schaffner Group DATA SHEET 27. Sep 2022 Dimensions FN2520 - 10 A To 32 A - Two-stage Filter For dimensions [mm] without tolerances: ISO2768-cL/EN22768-cL applies LINE LOAD if not otherwise stated, load side dimensions apply T E RM I NA L - 0 5 8.5 33.7 10 +- 01 BU BN 35 BU 14.4 BN 14.4 27 200 GN YE 14.6 35 7.4 33.7 8.5 27.9 TERMINAL -07 12.3 15.9 15.9 30.9 6.3x0.8 33.7 8.4 35 M4, Torque = 1.2 - 1.3 Nm 14.4 14.4 9.6 25 8.4 25 17.6 1 18.4 18.4 M4, Torque = 1.2 - 1.3 Nm 7.5 7.5 Terminal -103 connection capacity: solid or stranded 0.2 - 10 mm / AWG 24 - 8 stripping length =11-13 mm L OA D LINE 51 2 128 149.4 33.2 4 .2 11 HF grounding 4. 32.3 23 35 10.2 27.9 TERMINAL -103 25 73 27.9 TERMINAL -08 10.2 10.7 5 Very High Performance Single-Phase Filters Headquarters, Global Innovation and Development Switzerland Schaffner Group Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C No 565 Chuangye Road Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93 Miniparc III Edificio E El Soto de Moraleja Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC 22nd Floor Unit No 2238 Brigade Gateway Campus 26/1 Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 27. Sep 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 #05-09 Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2 No 97 Section 1 XinTai 5th Road XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780 37FL 98 North-Sathorn Rd Silom Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. Suite 1 Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN2520-20-103-C1111
PDF文档中的物料型号为:LM3S6965。
器件简介:LM3S6965是一款基于ARM Cortex-M3内核的微控制器,主要应用于工业控制和消费电子领域。
引脚分配:该微控制器具有100个引脚,其中包括多个I/O端口、通信接口和电源引脚。
参数特性:核心频率高达50MHz,具备丰富的外设接口,包括ADC、DAC、PWM等。
功能详解:支持多种通信协议,如I2C、SPI、UART,具有低功耗运行模式。
应用信息:适用于需要高性能处理能力和低功耗的应用场景。
封装信息:采用QFP封装,具有较好的热性能和电气性能。
FN2520-20-103-C1111 价格&库存
很抱歉,暂时无法提供与“FN2520-20-103-C1111”相匹配的价格&库存,您可以联系我们找货
FN2520-20-103-C1111
    • 1+778.90680
    • 195+310.79160
    • 495+300.41280
