FN9274B-15-05
FN9274B-15-05
    SCHAFFNER(夏弗纳)
    电源接入连接器 插座,公型片状插脚 IEC 320-C18 面板安装,法兰
FN9274B-15-05 数据手册
DATASHEET IEC Inlet Filters FN 9274 Versatile Medical Class II EMC/EMI Filter Medical filter suitable for compliance with Protection Class II (ME) according IEC 60601-1 Approvals & Compliances Fulfills the requirement for two MOPP (means of patient protection), compliant with IEC/EN 60601-1 No leakage current to earth Rated currents up to 15 A Excellent performance/size ratio Front mount, rear mount and snap-in versions (B, MB and S1B type) Plastic enclosure for higher dielectric strength insulation Fast-on terminals or wire leads V-lock compatible The FN9274 IEC inlet filter is suitable for compliance with Class II ME equipment. It incorporates an EMC filter into a C18 IEC inlet that offers excellent filter attenuation in a compact housing. The filter is available with two connection variants on the load side. The cable version is touch-safe by default. The pins of the fast-on-version are recessed in the plastic housing. In combination with insulated crimp connectors Class II compliance can be achieved for Fast-on version. The requirements for Two MOPP in IEC 60601-1:2005 + A1 regarding Leakage Currents, Insulation and Air Clearance and Creepage Distances and Ball Pressure test are fulfilled. Performance indicators Features and benefits Suitable for class II Medical Equipment (ME) 15 Fulfills the requirements for Two MOPP in IEC 60601-1 - Medical electrical equipment Fulfills the requirements in IEC/EN 62368-1 - Audio/ video, information and communication technology equipment Technical specifications Fulfills the requirements in IEC/EN 60950-1 Information technology equipment Temperature range (operation and storage) Design corresponding to -40°C to +100°C (40/100/21) Protection category IP 40 according to IEC 60529 (front side, with inserted plug) Overvoltage category Pollution degree Vibration and shock MTBF @ Rated amb. Temp./Voltage (MilHB-217F) II acc. IEC 60664-1 Flammability corresponding to Plastic Material: UL 94 V-0 Laces for -07 version: UL 94 VW-1 1 to 15 A @ 40°C max. DC to 400 Hz P –> N 760 VAC for 2 s P/N –> Ext. insulation 4 kVAC for 60 s acc. IEC 60601-1 up to 15A: UL 60939-3, CSA Std C22.1 No. 8-13 up to 10A: IEC/EN 60939-3, GB/T15287, GB/T15288 2 acc. IEC 60664-1 3M4 acc. IEC 60721-3-3 > 1,000,000 hours Fulfills the requirements in IEC/EN 60335-1 Household and similar electrical appliances Fulfills the requirements for Reinforced Insulation in IEC 61010-1 - Safety requirements All versions certified according UL/IEC 60939-3, C22.2 No. 8. CQC/CCC GB/T15287 and GB/T15288 Typical applications General medical devices (MDD) In-vitro diagnostic medical devices (IVDD) Test and measurement equipment Portable electrical and electronic equipment Single-phase power supplies, switch-mode power supplies (SMPS) Audio / video / communication equipment (IEC/UL 62368-1) Electrical schematic Cx R 2x L1 N N' P P' LOAD 250 VAC, 50/60 Hz LINE Maximum continuous operating voltage Rated currents Operating frequency High potential test voltage 2 Schaffner Group EMC/EMI Products Datasheets 26 Aug 2020 Filter selection table Filter Rated current Leakage current @ 40°C Inductance Capacitance Resistor Input Output L1 Cx R connections connections Weight * [A] [mA] [mH] [µF] [MΩ] FN9274XXB-1-ZZ 1 0.0 41.1 0.22 1 FN9274XXB-2-ZZ 2 0.0 20.1 0.22 1 C18 -05 -07
FN9274B-15-05
物料型号:FN9274XXB-1-ZZ, FN9274XXB-2-ZZ, FN9274XXB-4-ZZ, FN9274XXB-6-ZZ, FN9274XXB-10-ZZ, FN9274XXB-15-ZZ
器件简介:这是一种多功能的医疗级II类EMC/EMI滤波器,符合IEC 60601-1标准,适用于保护患者(两级MOPP),无漏电流到地,额定电流高达15A。
引脚分配:文档中未明确列出具体的引脚分配,但提到了Fast-on端子或导线引出两种连接方式。
参数特性: - 最大连续工作电压:250 VAC, 50/60Hz - 额定电流:1到15A@40°C最大 - 工作频率:直流至400Hz - 高电位测试电压:P->N 760VAC 2秒,P/N->外绝缘 4kVAC 60秒,符合IEC60601-1 - 工作和存储温度范围:-40°C至+100°C - 保护类别:IP 40(根据IEC60529,前侧,插入插头时) - 过电压类别:Il 符合IEC60664-1 - 污染等级:2 符合IEC60664-1
功能详解:该滤波器集成了EMC滤波器到C18 IEC入口,提供了在紧凑的外壳中的出色滤波衰减性能。它在负载侧有两种连接变体,电缆版本默认是触摸安全的。Fast-on版本的引脚嵌入在塑料外壳中,与绝缘压接连接器结合使用,可以为Fast-on版本实现II类合规性。
应用信息:适用于通用医疗设备、体外诊断医疗设备、测试和测量设备、便携式电子设备、单相电源、开关电源(SMPS)、音视频/通信设备等。
封装信息:提供了前安装、后安装和卡入式版本(B、MB和S1B类型),塑料外壳提供更高的介电强度绝缘。
FN9274B-15-05 价格&库存
很抱歉,暂时无法提供与“FN9274B-15-05”相匹配的价格&库存,您可以联系我们找货
FN9274B-15-05
  • 1+113.168701+14.52083
  • 10+96.1522010+12.33742
  • 25+90.1335125+11.56515
  • 60+84.7322660+10.87211
  • 120+80.68945120+10.35337
  • 300+75.64143300+9.70565
  • 540+72.57137540+9.31173
  • 1020+69.391151020+8.90367
库存:49
