101020341
101020341
    SEEED(矽递科技)
    TCS34725 颜色 传感器 Grove 平台评估扩展板
101020341 数据手册
      Grove ‐ I2C Color Sensor V2  SKU 101020341        Description  This is an updated version of the Grove ‐ I2C Color Sensor module. The new version is based on the color  sensor TCS34725FN with digital output I2C. We also changed the circuit's layout based on the new  sensor. Based on the 8*2 array of filtered photodiodes and 16‐bits analog‐to‐digital converters, you can  gain the color chromaticity of ambient light or the color of objects. Of the 16 photodiodes, 4 have red  filters, 4 have green filters, 4 have blue filters and 4 have no filter(clear). With the synchronization input  pin, external pulsed light source can provides precise synchronous conversion control.      Features   Grove compatible interface   16‐Bit digital output with I 2C at 400 kHz   SYNC Input Synchronizes Integration Cycle to Modulated Light Sources   Programmable interrupt function with User‐Defined Upper and lower threshold settings    Technical Details    Dimensions  42mm x 23mm x 10mm  Weight  G.W 10.4g      Battery  Exclude  Supply Voltage  3.3/5V  Operating temperature range  ‐40Ԩ to 85Ԩ  Interface  I2C                                 https://www.seeedstudio.com/Grove‐I2C‐Color‐Sensor‐V2‐p‐2890.html 7‐19‐17
101020341 价格&库存
很抱歉,暂时无法提供与“101020341”相匹配的价格&库存,您可以联系我们找货
