101020472
101020472
    SEEED(矽递科技)
    LED RGB 闪光 Opto Grove 平台评估扩展板
101020472 数据手册
Grove - Variable Color LED V1.1 SKU 101020472 The Grove - Variable Color LED is an RGB LED that can be controlled by both digital and PWM signal, there are three changable resistors on board, with which you can change the color simply and quickly. This is the V1.1 version of this product, comparing to the first version, we add a logic IC to the new one, so that it can better work wtih logic DC Jack. However if you don't use a logic DC jack with this RGB LED, there is no difference in using this or the old version. Just get one and start your colorful LED project! Technical Details Dimensions 20mm x 20mm x 30mm Weight G.W 7g Battery Exclude Working Voltage 3.3v / 5v Part List Grove - Variable Color LED V1.1 1 Grove - Cable 1 Documents • 【Eagle File】Grove - Variable Color LED v1.1 Eagle File.zip https://www.seeedstudio.com/Grove-Variable-Color-LED-V1.1-p-3029.html 3-12-18
101020472 价格&库存
很抱歉,暂时无法提供与“101020472”相匹配的价格&库存,您可以联系我们找货
