101020614
101020614
    SEEED(矽递科技)
    LMV358,NE555 潮湿 传感器 Grove 平台评估扩展板
101020614 数据手册
      Grove ‐ Capacitive Moisture Sensor (Corrosion Resistant) SKU 101020614   The Grove ‐ Capacitive Moisture Sensor (Corrosion Resistant) is a soil moisture sensor based on capacitance changes. Compared with resistive sensors, capacitive sensors do not require direct exposure of the metal electrodes, which can significantly reduce the erosion of the electrodes. Hence, we call it Corrosion Resistant. It is important to note that this sensor can only qualitatively test the humidity of the soil and cannot measure quantitatively. Which means when the humidity of the soil rises, the value of the output decreases; conversely, when the humidity decreases, the output value becomes higher. Note We've Released the Grove Selection Guide and hope to help you find the Grove suit you best. Feature    Capacitive Style Corrosion Resistant Built‐in Amplifier Typical Applications   Soil moisture detection Automatic watering of plants Pin Out ECCN/HTS ECCN  EAR99  HSCODE  9025900090  USHSCODE  90230000  UPC  84145412195                                 https://www.seeedstudio.com/Grove‐Capacitive‐Moisture‐Sensor‐Corrosion‐Resistant.html/9‐12‐19
101020614 价格&库存
很抱歉,暂时无法提供与“101020614”相匹配的价格&库存,您可以联系我们找货
  • 1+61.631601+7.84960
库存:88
101020614
  • 1+57.291021+7.42601
  • 1+42.86336
库存:50
