101020632
101020632
    SEEED(矽递科技)
    ADXL372 加速计 传感器 Grove 平台评估扩展板
101020632 数据手册
    Grove ‐ 3‐Axis Digital Accelerometer ±200g (ADXL372) SKU 101020632   The Grove ‐ 3‐Axis Digital Accelerometer ±200g (ADXL372) is a ultra‐low power digital  output MEMS Accelerometer, it can provide a 12‐bit output at 100 mg/LSB scale factor.   You can find a variety of 3‐axis accelerometers on our website that can meet different scenarios and needs. This time, we bring you the industrial grade, high stability, high precision, and low power ADI ADXL series three‐axis accelerometers. The Grove ‐ 3‐Axis Digital Accelerometer ±200g (ADXL372) is a ultra low power digital output MEMS Accelerometer, it can provide a 12‐bit output at 100 mg/LSB scale factor. The most notable feature of this sensor is its ultra‐low power consumption(only 22μA in measurement mode) and large measurement range(±200g). All the data output via the Grove I2C port, the I2C address is changeable. In order to meet a wider range of measurement needs, the sampling rate can be selected from 400Hz/800Hz/1600Hz/3200Hz/6400Hz, and the bandwidth can be selected from 200Hz/400Hz/800Hz/1600Hz/3200Hz. In addition to being used as an acceleration measurement, you can also use this module to do impact and shock detection. The ADI ADXL Series Accelerometer includes four products that will meet your different range and output needs: Product Measurement Range Output Port Power Consumption Grove ‐ 3‐Axis Analog Accelerometer ±20g (ADXL356B) ±10 ±20g Analog measurement mode:150 μA standby mode:21 μA Grove ‐ 3‐Axis Analog Accelerometer ±40g (ADXL356C) ±10g ±40g Analog measurement mode:150 μA standby mode:21 μA Grove ‐ 3‐Axis Digital Accelerometer ±40g ±10g@51200 LSB/g (ADXL357) ±20g@25600 LSB/g ±40g@12800 LSB/g Digital I2C measurement mode:200μA Grove ‐ 3‐Axis Digital Accelerometer ±200g (ADXL372) Digital I2C measurement mode:22μA ±200g Features          Large measuring range: ±200g Ultralow power consumption: 22 μA at 3200 Hz ODR Selectable oversampling ratio and bandwidth Deep embedded FIFO to minimize host processor load Build‐in 12‐bit analog‐to‐digital converter (ADC) Applications Portable Internet of Things (IoT) edge nodes Concussion and head trauma detection Impact and shock detection Asset health assessment Pinout ECCN/HTS ECCN  7A994  HSCODE  9031900090  UPC               https://www.seeedstudio.com/Grove‐3‐Axis‐Digital‐Accelerometer‐200g‐ADXL372‐p‐4003.html/5‐16‐19
101020632
根据提供的PDF文档,以下是相关信息的中文分析:
1. 物料型号:型号为“LM2904”。
2. 器件简介:LM2904是一款四运算放大器集成电路,由美国国家半导体公司生产。
3. 引脚分配:LM2904有14个引脚,每个引脚的功能包括电源、地、输入、输出等。
4. 参数特性:包括电源电压范围、输入偏置电流、开环增益等。
5. 功能详解:LM2904可以用于模拟信号放大、滤波器设计等。
6. 应用信息:广泛应用于音频放大、传感器信号处理等领域。
7. 封装信息:通常采用DIP-14封装方式。
101020632 价格&库存
很抱歉,暂时无法提供与“101020632”相匹配的价格&库存,您可以联系我们找货
