101020636
101020636
    SEEED(矽递科技)
    GROVE - 12-CHANNEL CAPACITIVE TO
101020636 数据手册
      Grove ‐ 12‐Channel Capacitive Touch Keypad (ATtiny1616) SKU 101020636   The Grove 12 button Capacitive Touch Keypad is built around the ATtiny1616, an AVR® 8‐bit processor running at up to 16 MHz. ATtiny1616 is a low‐power, high‐performance chip integrated QTouch® peripheral touch controller which supports capacitive touch interfaces with proximity sensing and driven shield. With this module, you can easily create an arduino password keypad or a DIY phone keypad. We made this keypad into a 3x4 form, just like the layout of a mobile phone keyboard. The traditional keypad requires 3 vertical lines and 4 horizontal lines to scan, which will occupy 7 I/O pins of the microcontroller. With the help of ATtiny1616 and Grove connector, only RX and TX two pins are enough for Grove ‐ 12‐Channel Capacitive Touch Keypad. You can easily use this module with a microcontroller with a hardware UART interface, or you can use the software UART to read the button input with two normal I/O pins. All in all, the Grove 12 button Capacitive Touch Keypad is an easy‐to‐use module that requires very little code, especially when you use it with Grove compatible mainboards, no soldering, just plug and play. Note We've Released the Grove Selection Guide and hope to help you find the Grove suit you best. Features       Low Power ATtiny1616 controller 3.3V / 5V compatible Capacitive touch, high sensitivity 12 button keypad 4 pin Grove UART connector On‐board LED indicator Applications    Phone keypad Password access Extended input interface Hardware Overview   Figure 1. hardware overview ECCN/HTS ECCN  EAR99  HSCODE  9031900090  UPC                                  https://www.seeedstudio.com/Grove‐12‐Channel‐Capacitive‐Touch‐Keypad‐ATtiny1616‐p‐4068.html/9‐12‐19
101020636 价格&库存
很抱歉,暂时无法提供与“101020636”相匹配的价格&库存,您可以联系我们找货
