101020639
101020639
    SEEED(矽递科技)
    GROVE 3AXIS DIGITAL ACCELEROMETE
101020639 数据手册
    Grove ‐ 3‐Axis Digital Accelerometer ±40g (ADXL357) SKU 101020639   The Grove ‐ 3‐Axis Digital Accelerometer ±40g (ADXL357) is a digital output MEMS Accelerometer. This sensor  has three different selectable measuring ranges and accuracies: ±10g@51200 LSB/g, ±20g@25600 LSB/g,  ±40g@12800 LSB/g.  You can find a variety of 3‐axis accelerometers on our website that can meet different scenarios and needs. This time, we bring you the industrial grade, high stability, high precision, and low power ADI ADXL series three‐axis accelerometers. The Grove ‐ 3‐Axis Digital Accelerometer ±40g (ADXL357) is a digital output MEMS Accelerometer. This sensor has three different selectable measuring ranges and accuracies: ±10g@51200 LSB/g, ±20g@25600 LSB/g, ±40g@12800 LSB/g. You just need to do little calibration work to get a relatively accurate result. It output all the data via grove I2C port, and the I2C address is also selectable. What's more, we also provide two interrupt output pins which can be configured into 4 modes. The ADI ADXL Series Accelerometer includes four products that will meet your different range and output needs: Product Measurement Range Output Port Power Consumption Grove ‐ 3‐Axis Analog Accelerometer ±20g (ADXL356B) ±10 ±20g Analog measurement mode:150 μA standby mode:21 μA ±10g Grove ‐ 3‐Axis Analog Accelerometer ±40g (ADXL356C) ±40g Analog measurement mode:150 μA standby mode:21 μA Grove ‐ 3‐Axis Digital Accelerometer ±40g (ADXL357) Digital I2C measurement mode:200μA Digital I2C measurement mode:22μA ±10g@51200 LSB/g ±20g@25600 LSB/g ±40g@12800 LSB/g ±200g Grove ‐ 3‐Axis Digital Accelerometer ±200g (ADXL372)        Features Industry leading noise, minimal offset drift over temperature, and long‐term stability, enabling precision applications with minimal calibration. Hermetic package offers excellent long‐term stability 0 g offset vs. temperature (all axes): 0.75 mg/°C maximum Ultralow noise density (all axes): 80 μg/√Hz Build‐in 20‐bit analog‐to‐digital converter (ADC) Low drift, low noise, and low power Support two channel interrupt output Support FIFO(96*21‐bit) Applications       Inertial measurement units (IMUs)/altitude and heading reference systems (AHRSs) Platform stabilization systems Condition monitoring Seismic imaging Tilt sensing Robotics Pinout ECCN/HTS ECCN  7A994  HSCODE  9031900090 UPC          https://www.seeedstudio.com/Grove‐3‐Axis‐Digital‐Accelerometer‐40g‐ADXL357‐p‐4005.html/5‐15‐19
101020639 价格&库存
很抱歉,暂时无法提供与“101020639”相匹配的价格&库存,您可以联系我们找货
