Grove ‐ 12‐bit Magnetic Rotary Position Sensor / Encoder (AS5600)
SKU 101020692
The Grove ‐ AS5600 is a programmable 12‐bit high‐resolution contactless magnetic rotary position
sensor. Compared with the traditional potentiometer, it has significant advantages: high precision, non‐
contact, no rotation angle limitation.
If you want to know more about this demo, please check Open‐Source Inverted Pendulum
We all know about the potentiometer, quoted from Wikipedia "A potentiometer is a three‐terminal
resistor with a sliding or rotating contact that forms an adjustable voltage divider." Simply put, the
potentiometer converts relative position information into electrical signals. But the traditional
potentiometer needs to be in contact with the object being measured. What about scenes that need
to be contactless, such as high‐speed motor, or high‐precision robot arm? Well, the answer to the
contactless potentiometer solution is the Grove ‐ 12‐bit Magnetic Rotary Position Sensor
(AS5600).
sensor. The Grove ‐ AS5600 can work as magnetic potentiometer or magnetic encoder with
excellent reliability and durability. Compared with the traditional potentiometer/encoder, the
Grove ‐ AS5600 has significant advantages: high precision, non‐contact, no rotation angle
limitation. All those advantages make it is perfectly suitable for non‐contact angle measurement
applications, such as the robot arm, tripod head, motor closed‐loop control, machine tool axis
positioning.
AS5600 is based on the Hall Effect, the build‐in Hall sensor can detect changes in the direction of
the magnetic field, thus, there is also no rotation angle limit. Then the magnetic field direction
information is amplified by the amplifier, with the help of the build‐in 12 bit A/D, the AS5600
module can output 4096 positions per round. The output is selectable, you can either use the I2C
interface to output the RAW data or output the PWM wave/Analog wave via the OUT pin.
Meanwhile, the maximum angle is also programmable, you can set the maximum angle from 18° to
360°, which means that the measured angular accuracy is up to 18/4096.
AS5600 is excellent for the non‐contact rotary position sensor, so we made this AS5600 Breakout
Board in the Grove form factor. With the Grove I2C connector, you can easily connect this AS5600
module to Arduino. Also, we provide the full function AS5600 Arduino library.
Attention
The AS5600 has certain requirements for the magnetic field to be measured. Please use a magnet similar
in size to the chip. The module should be measured as close as possible to the magnetic field and the
AS5600 sensor center should be aligned with the center of the magnetic field. The vertical distance is
preferably from 0.5 mm to 3 mm.
Applicable magnet description
Since the AS5600 has certain requirements for the magnetic field to be measured. We recommend a
round magnet that is about the same size as the chip.
Features
Non‐contact, no rotation angle limitation
12‐bit high‐resolution, 4096 positions per round
Grove I2C, PWM/Analog Output
Great flexibility on angular excursion: Maximum angle programmable from 18° up to 360°
Applications
Motor closed‐loop control
Robot arm
Tripod head
Industrial machine control
Hardware Overview
ECCN/HTS
ECCN
EAR99
HSCODE
9031900090
UPC
https://www.seeedstudio.com/Grove‐12‐bit‐Magnetic‐Rotary‐Position‐Sensor‐AS5600‐p‐4192.html/9‐12‐19
很抱歉,暂时无法提供与“101020692”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+108.49680
- 200+41.99040
- 500+40.51080
- 1000+39.78720
