101020712
101020712
    SEEED(矽递科技)
    HX711 称重计 传感器 Grove 平台评估扩展板
101020712 数据手册
Grove - ADC for Load Cell (HX711) SKU 101020712 The Grove - ADC for Load Cell (HX711) is a 24-bit A/D converter designed specifically for the load cell, it's quite easy to build your Arduino weight sensor system with this module. PRODUCT DETAILS Well, you can find more than a dozen load cells on Seeed Bazaar, however, it is never going to be easy to use these load cells to measure weight. Let's see, you need to find a proper ADC and stable power source, then do some wiring and calibration, at last, you still need to do the coding... Time is long, life is short, Grove - ADC for Load Cell is born to save your time and make it easy to use load cells. How easy? Easy and peasy! The Grove - ADC for Load Cell (HX711) is a 24-bit A/D converter designed specifically for the load cell. It contains an on-chip low noise programmable amplifier with an optional gain of 32, 64 and 128. The HX711 chip integrates a regulated power supply, an on-chip clock oscillator, and other peripheral circuits, which have the advantages of high integration, fast response, and strong anti-interference. With the Grove connector and 4-pin screw terminal, it becomes quite easy to connect the load cell and microcontroller, no soldering required. You can build your own Arduino weigh sensor system in just a few simple steps. Features • Working voltage: 2.6V--5.5V (Note: The module measurement accuracy is related to the supply voltage. The higher the voltage, the higher the accuracy.) • Working current:
101020712 价格&库存
很抱歉,暂时无法提供与“101020712”相匹配的价格&库存,您可以联系我们找货
  • 1+41.827201+5.43530
库存:276
