101020753
101020753
    SEEED(矽递科技)
    CD4060B,LMV324 水质 传感器 Grove 平台评估扩展板
101020753 数据手册
    Grove ‐ TDS Sensor/Meter For Water Quality (Total Dissolved Solids) SKU 101020753 An Arduino-compatible TDS(Total Dissolved Solids) sensor/meter for measuring TDS levels in water to indicate the water quality. It can be implemented in fields such as homemade water filter, hydroponics, aquarium and others related to testing water quality. Concerned about your water quality? Why not make yourself a TDS meter to monitor water quality to tell you whether the water meets standards of drinking! Tip This product can also be compatible with Raspberry Pi Series with the help of 4-Channel 16-Bit ADC For Raspberry Pi (ADS1115)! Features     Analog Signal, easy to implement Support 3.3/5V Input Voltage Good Arduino Compatibility, where 0 ~ 2.3V Output Voltage can be easily implemented in 3.3/5V control system Waterproof TDS Probe Description The Grove - TDS Sensor detects the Total Dissolved Solids (TDS) levels in the water which can be used to indicate the water quality. The Grove - TDS Sensor can be applied in water quality applications such as TDS meter, well water, aquarium, hydroponics, etc. It supports 3.3/5V input voltage and 0 ~ 2.3V Output Voltage making it easy to be compatible with all Arduino Boards. The sensor also provides a waterproof probe, making the testing process much easier to handle. What is TDS and why should you care TDS = Total Dissolved Solids, is a measure of the dissolved combined content of all inorganic and organic substances present in water. Typically, the higher the TDS value, the more substances dissolved in water. Hence, higher levels of Total Dissolved Solids (TDS) can indicate that water has more contaminants that can pose health risks. Applications      TDS meter/TDS tester Swimming pool Aquarium Well water Hydroponics Specifications Grove - TDS Sensor       Input Voltage: 3.3/5V Output Voltage: 0 ~ 2.3V Working Current: 3 ~ 6mA TDS Measurement Range: 0 ~ 1000ppm Power indication LED Connection Interface: Grove 4-Pin / XHB 2.54mm 2P Waterproof Probe   Cable Length: 60cm Connection Interface: XHB 2.54mm 2P Hardware Overview Note     The Waterproof TDS probe cannot be used in water above 70°C. The sensor cannot be used to measure flowing water. The sensor cannot be used to measure water with high pollution concentration. The Grove sensor itself is not waterproof. Part List    Grove - TDS Sensor x 1 20cm Grove Cable x 1 Waterproof TDS Probe x 1 Dimensions 20 x 40 cm Weight 0.025 ECCN/HTS HSCODE UPC                 9027900000                       https://www.seeedstudio.com/Grove‐TDS‐Sensor‐p‐4400.html/1‐24‐20
101020753 价格&库存
很抱歉,暂时无法提供与“101020753”相匹配的价格&库存,您可以联系我们找货
