101020812
101020812
    SEEED(矽递科技)
    DPS310 气压计 传感器 Grove 平台评估扩展板
101020812 数据手册
    Grove - High Precision Barometric Pressure Sensor (DPS310) SKU 101020812 Grove - DPS310 is a high precision barometric pressure sensor, it can measure air pressure change caused by height changes in the centimeter level. As shown in the figure below, when the height changes in centimeter‐level, the barometer reading inside the mobile phone has almost no change, and the output of the Grove DSP310 changes significantly. What is called "high precision"? That is high precision!!! Features      High Pressure Precision: ± 0.002 hPa (or ±0.02 m) High Pressure Accuracy: ± 0.06 hPa (or ±0.5 m)-Relative; ± 1 hPa (or ±8 m)-Absolute Wide Range: Pressure: 300 –1200 hPa; Temperature: -40 – 85 °C. Easy to Use: Grove IIC (with interrupt) / SPI Low power consumption We can't wait to introduce you to this marvelous Barometer Sensor! With 0.06 PaRMS (or 0.01m) pressure data resolution, ± 0.002 hPa (or ±0.02 m) pressure sensor precision and ± 0.06 hPa (or ±0.5 m) relative accuracy, it's probably one of the best barometric pressure sensors, incredibly, it only costs $ 5.9! The Grove - High Precision Barometric Pressure Sensor is based on Infineon latest DPS310. The DPS310 is a miniaturized Digital Barometric Air Pressure Sensor with high accuracy and low current consumption, capable of measuring both pressure and temperature. The pressure measurement range of this sensor is 300 -1200 hPa, and the temperature measurement range is -40-85 ° C. Therefore you can use it to measure the air pressure, altitude, temperature, and build your own Arduino barometer. This sensor is not only highly accurate but also extremely easy to use. You can flexibly choose the onboard Grove IIC interface or 6-pin SPI interface. When it comes to Grove IIC port, you can just plug it into the Seeeduino or Arduino+baseshiled, no wiring, no soldering required, and works for both 3.3V/5V system. All in all, it's a time and money saving high precision Arduino barometric pressure sensor solution, don't miss it. BMP280 vs. BME280 vs. DPS310 We've already released the Grove-BMP280 and Grove-BME 280 barometric pressure sensors, let us show you how powerful Grove-DPS310 is through the comparison of the table below. iTEM Grove-BMP280 Grove-BME280 Grove-DPS310 Pressure Range 300 ~ 1100 hPa 300 ~ 1100 hPa 300 ~ 1200 hPa Temperature Range -40 ~ 85 ℃ -40 ~ 85 ℃ -40 ~ 85 °C. Pressure Precision ? ? ± 0.002 hPa (or ±0.02 m) Pressure Accuracy (Absolute) Pressure Accuracy (Relative) Pressure Resolution Humidity Communication Price ± 1 hPa (or ±8 m) ± 1 hPa (or ±8 m) ± 1 hPa (or ±8 m) ± 0.12 hPa ± 0.06 hPa (or ±0.5 m) 0.18 Pa 0.18 Pa 0.06 Pa - 0 ~ 100% - I2C/SPI I2C/SPI I2C/SPI $8.9 $17.0 $5.9 ± 0.12 hPa Hardware Overview Typical Application      Indoor Navigation (floor detection e.g. in shopping malls and parking garages) Health and Sports (accurate elevation gain and vertical speed) Outdoor Navigation (GPS start-up time and accuracy improvement, dead-reckoning e.g. in tunnels) Weather Station('Micro-weather' and local forecasts) Drones (flight stability and height control) Part List   Grove - High Precision Barometric Pressure Sensor (DPS310) x1 20cm Grove Cable x1 ECCN/HTS HSCODE UPC 9026900000                           https://www.seeedstudio.com/Grove‐High‐Precision‐Barometer‐Sensor‐DPS310‐p‐4397.html/1‐14‐20
101020812 价格&库存
很抱歉,暂时无法提供与“101020812”相匹配的价格&库存,您可以联系我们找货
