101090001
101090001
    SEEED(矽递科技)
    MAKER LINE - SIMPLIFYING LINE SE
101090001 数据手册
      MAKER LINE ‐ Simplifying Line Sensor (PIC16F1827) SKU 101090001 Maker Line - Simplifying Line Sensor is a infrared Robotic sensor for Robotic car to track traveling line. Do you want to build up a robot car? If the answer is yes, then you are supposed to get a view of this product-Simplifying Line Sensor. This sensor can test the robot car whose moving track is following the planned path. This line sensor is assembled the PIC16F1827 chip, which has a CPU speed of 8 MIPS that means fast performance. This chip also can afford the communication peripherals, cause it support some basic interface such as UART, SPI, I2C. The sensor has 5 infrared detectors in the front to measure the distance between the line and the sensor. 5 detectors are able to emit 5 digital signals corresponding to 5 digital pins. Except for the digital value, you can still get the analog signal from the analog pin. With the help of digital and analog signal, you may get a higher precision result for your project. Feature         Operating Voltage: DC 3.3V and 5V compatible (With reverse polarity protection). Recommended Line Width: 13mm to 30mm. Selectable line color (light or dark). Sensing Distance (Height): 4mm to 40mm (Vcc = 5V, Black line on white surface). Sensor Refresh Rate: 200Hz Easy calibration process. Dual Output Types: 5 x digital outputs represent each IR sensor state, 1 x analog output represents line position. Support wide range of controllers such as Arduino, Raspberry Pi, etc. Interface Dimension ECCN/HTS HSCODE 9031900090 UPC     https://www.seeedstudio.com/MAKER‐LINE‐p‐4273.html/10‐30‐19
101090001 价格&库存
很抱歉,暂时无法提供与“101090001”相匹配的价格&库存,您可以联系我们找货
