101990440
101990440
    SEEED(矽递科技)
    光学传感器 6.69" ~ 314.96"(17 ~ 800cm) UART 输出
101990440 数据手册
        PSK‐CM8JL65‐CC5 ToF Infrared Distance Measuring Sensor SKU 101990440   Description    By detecting the phase difference of the light pulse to perceive the distance between the target, sensor can  achieve the millimeter resolution.   The unique HALIOS photoelectric detection technology enhances the strong light immunity, adapts to the  outdoor strong sunlight environment, has strong temperature adaptability and small drift.   Solid solution; limited influence by color of target and Surface roughness and material in testing result.   Small size, small photosensitive surface, low product height   Connection:4 core, 0.8mm spacing connector  Specification   Item: PSK‐CM8JL65‐CC5   Voltage: 5VDC   Current: ≤85mA   Light source: Infrared LED (850nm)   Ambient light: 100.0001x   Divergence angle: ±1.4°   Output: UART‐TTL   Response efficiency: 25HZ   Testing range: 0.17‐8m   Resolution: 1mm   Repeatability: 6%   Detection accuracy: 5%   Color sensitivity: ≤10%   Temperature: ‐15 to +55°C   Protection level: IP50   Material: ABS   Connection: 4 core, 0.8mm spacing connector   Weight: ≤10g        Connection Diagram:    Dimension:    ECCN/HTS  ECCN  HSCODE  6A992      https://www.seeedstudio.com/PSK‐CM8JL65‐CC5‐ToF‐Infrared‐Distance‐Measuring‐Sensor‐p‐4028.html/5‐15‐19
101990440 价格&库存
很抱歉,暂时无法提供与“101990440”相匹配的价格&库存,您可以联系我们找货
