101990501
101990501
    SEEED(矽递科技)
    PIXHAWK4 DIGITAL AIR SPEED SENSO
101990501 数据手册
      Pixhawk4 Digital Air Speed Sensor SKU 101990501   The Pix32 digital differential airspeed sensor has a very low offset, a high resolution and, best of all, does not suffer from the noise induced by long cables and offsets in the ratio‐ metric output on the APM 2.6 ana log airspeed sensor. Featuring a Measurement Specialties 4525DO sensor, with 1 psi measurement range (roughly up to 100 m/s or 360 km/h or 223 mp/h), the Pix32 Airspeed Sensor Kit enables a resolution of 0.84 Pa, with data delivered at 14 bits from a 24 bit delta‐sigma ADC. It also measures temperature to allow calculation of true airspeed from indicated airspeed using the MS5611 static pressure sensor on Pix32. Not influenced by the heat of nearby processing components, it is much closer to the air temperature than with previous ana log sensor setups. Supported on all Pix32 and PX4 autopilot generation boards, this kit comes with M3 / 6‐32 mounting holes. Part List: 1 x Digital Air Speed Sensor 1 x 4pin cable 1 x Rubber tubing 1 x Tube ECCN/HTS ECCN  ERA99  HSCODE  9015800090   UPC      https://www.seeedstudio.com/Pixhawk4‐Digital‐Air‐Speed‐Sensor‐p‐4063.html/6‐27‐19
101990501
物料型号: - 型号:Pixhawk4 Digital Air Speed Sensor - SKU:101990501
器件简介: - Pixhawk4 数字差分空气速度传感器,具有非常低的偏移量、高分辨率,并且不会受到APM 2.6模拟空气速度传感器上长电缆和比率-度量输出上产生的噪声影响。
引脚分配: - 4针电缆
参数特性: - 测量范围:1 psi(大约100米/秒或360公里/小时或223英里/小时) - 分辨率:0.84帕斯卡 - 数据来源:24位增量-西格玛ADC的14位数据 - 温度测量:使用MS5611静压传感器从指示空速计算真实空速
功能详解: - 该传感器不受附近处理元件热量的影响,比以往的模拟传感器设置更接近空气温度。
应用信息: - 支持所有Pix32和PX4自动驾驶控制板
封装信息: - 包含M3/6-32安装孔
ECCN/HTS: - ECCN:ERA99 - HSCODE:9015800090
101990501 价格&库存
很抱歉,暂时无法提供与“101990501”相匹配的价格&库存,您可以联系我们找货
