101990620
101990620
    SEEED(矽递科技)
    光学传感器 3.94" ~ 472.44"(10 ~ 1200cm) I²C,UART 输出
101990620 数据手册
TFmini S LiDAR module - Short-Range ToF LIDAR Range Finder SKU 101990620 TFmini S LiDAR module - Short-Range ToF LIDAR Range Finder is a distance sensor of LIDAR which can emit near-infrared ray and measure the phase difference between the emitting ray and reflected ray to calculate the distance through ToF. Key Features • • • High Sensitivity: Emits near-infrared ray and catches the reflected ray which can give the response in a short time. High Precision: ToF method is used to calculate the phase difference between the emitting and reflected rays to measure the distance. The accuracy is ±6cm for 0.1-6m range and ±1% for the 6m12m range. Selectable Interface: I2C and UART interface for developers to choose from. Description TFmini S LiDAR module - Short-Range ToF LIDAR Range Finder is a distance sensor of LIDAR which can emit near-infrared ray and measure the phase difference between the emitting ray and reflected ray to calculate the distance through ToF. Because of the LIDAR principle, it is hard to give an accurate distance between the transparent objects like water or glass. However, it is still a sensitive distance sensor in measuring the moving object and calculate the distance between the object and TFmini in real-time. This distance sensor leaves I2C and UART interface for developers and you can simply plug TFmini through the TTL to USB converter to the PC and get the distance data on your computer. As for the software, there is a test software upper computer software of TFmini that you can download to observe the distance changing when the object is moving in real-time. If you want to view more details, please click the link - datasheet. Specification Name of parameter Product performance Optical parameters Values Operating range 0.1m~12m@90% reflectivity Accuracy ±6cm@(0.1-6m)±1%@(6m-12m) Distance resolution 5mm Frame rate 100Hz Ambient light immunity 70 Klux Operation temperature 0℃~60℃ Light source VCSEL Central wavelength 850nm Photobiological safety Class1(IEC60825) FOV 2° Electrical parameters Others Supply voltage 5V±0.1V Average current ≤140mA Power consumption ≤0.7W Peak current 800mA Communication level LVTTL(3.3V) Communication interface UART / I2C Housing ABS+PC Storage temperature -20℃~75℃ Cable length 30cm Weight 12g Dimension 42mm*15mm*16mm(L*W*H) Part List 1x TFmini S LiDAR module - Short-Range ToF LIDAR Range Finder 1x JST GH1.25 - 4P cable (Both two sides are JST GH1.25 - 4P interfaces) 1x JST GH1.25 - 4P cable (One side for JST GH1.25 - 4P interface and the other side for 4 Dupont Line male type) ECCN/HTS HSCODE 9031900090 UPC https://www.seeedstudio.com/TFmini-S-LiDAR-module-Short-Range-ToF-LIDAR-Range-Finder-p-4425.html/1-14-20
101990620 价格&库存
很抱歉,暂时无法提供与“101990620”相匹配的价格&库存,您可以联系我们找货
