Grove - AHT20 I2C
Industrial Grade
Temperature and
Humidity Sensor
SKU 101990644
Grove AHT20 Temperature and
Humidity sensor is an industrialgrade sensor based on AHT20.
Note
The color of the arrival PCB is blue!!! The Grove interface has already been
soldered on the PCB.
Key Features
Temperature measurement range -40 ~ 85°C, Humidity measurement
range 0 ~ 100% RH
Digital output, Grove I2C interface
Excellent long-term stability
SMD package suitable for reflow soldering
Quick response and strong anti-interference ability
Compatible with Arduino
4-pin interface reserved
Description
Grove AHT20 Temperature and Humidity sensor is based on AHT20,
compared with Grove - Temperature & Humidity Sensor Pro
(AM2302/DHT22), AHT20 is a new generation of temperature and humidity
sensor embedded with a dual-row flat and no-lead SMD package, suitable
for the reflow soldering. AHT20 is equipped with a newly designed ASIC
chip: an improved MEMS semiconductor capacitive humidity sensor, and a
standard on-chip temperature sensor. The output is I2C protocol with the
Grove interface.
The performance of AHT20 is more stable in harsh environments
compared with the previous generation of temperature and humidity
sensor,as a matter of fact, AHT20 is fittable in most industrial scenarios.
Dimensions
24x20x12(mm)
What is Grove?
Grove makes it easier to connect, experiment, and simplify the prototyping
process. No jumpers or soldering required. We have developed more than
300 Grove modules, covering a wide range of applications that can fulfill a
variety of needs. Not only are these open hardware, but we also have
open-source software.
Tip
Also, check our blog 9 Types of Temperature Sensors You Should Know to
compare different temperature sensors for your next environmental project!
ECCN/HTS
HSCODE
9025900090
UPC
6
https://www.seeedstudio.com/Grove‐AHT20‐I2C‐Industrial‐grade‐temperature‐and‐humidity‐sensor‐p‐4497.html/3‐25‐20
很抱歉,暂时无法提供与“101990644”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+56.598581+7.26510
