Grove AC-Voltage Sensor
SKU 101991032
Grove AC Voltage Sensor is perfect for measuring RMS AC voltages for accurate DIY energy
meters. It has adjustable gain for different voltage inputs (120V-240V AC), and it supports a 5 3.3v DC power supply.
Smart home has been long regarded as eco-friendly and energy-efficient by applying IoT
technology. A simple energy efficiency definition is using less energy or fewer resources to
complete the same task (UN’s Sustainable Goal 12: Sustainable Consumption and Production).
You might be still wondering why you need an RMS AC voltage sensor for smart and
sustainable home applications. The RMS AC voltage sensor allows you to monitor different
voltage inputs and visualize the current-voltage status of your appliances.
For example, you can reduce power consumption by adjusting the voltage of a high-voltage
appliance at home. Since we don't know what the threshold of the right voltage is, an RMS AC
voltage sensor which helps you visualize the current-voltage status of the appliance.
This Grove Voltage Sensor is perfect for measuring RMS AC voltages for accurate DIY energy
meters. It features adjustable gain for different voltage inputs (120V-240V AC), the fact that this
sensor output is analog lets you integrate it with many different development boards, letting you
decide on the sampling frequency, and ADC resolution without limitations. It’s accurate enough
to measure the variations in voltage that high-power loads generate when they are turned on,
making it a great choice for creating smart energy meters.
Features
High adaptability: It has gained for different voltage inputs (120V-240V AC)
High compatibility: Using Analog as output, it can be compatible with many different
development boards
Accurately measure the voltage changes generated by high power loads when
they are turned on
Powerful IC: Equipped with MCP6002 core with Analog output
Easy to Use: Just sample plug and play which allows you to easily add wireless
capabilities.
Specification
Parameter
Range/Value
Input Voltage
5-3.3V
Output type
Analog
Module IC
MCP6002 (OPAMP)
Application
AC Voltage Meter.
Smart Energy Monitoring.
Machine Learning.
Loads Identification.
Home automation.
IoT projects.
ECCN/HTS
HSCODE
9030899090
USHSCODE
8473301140
UPC
EUHSCODE
8473302000
COO
CHINA
https://www.seeedstudio.com/Grove-AC-Voltage-sensor-p5540.html?queryID=b1dde30b8fd91e2176d56325ffbfce2e&objectID=5540&indexName=bazaar_retailer_products
2023
1-12-
很抱歉,暂时无法提供与“101991032”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+40.510771+5.26518
