ReSpeaker Core - Based On MT7688 and OpenWRT
SKU 102010088
Speech recognition with or without the internet
Web-based App set-up
Wireless Streaming via Airplay/DLNA
For Python and C/C++ developers
Enormous plug-ins
Extendable with Mic Array. Grove Extendable
Description
ReSpeaker is an open modular voice interface to hack things around you.
Let you interact with your home appliances, your plant, your office, your
internet-equipped devices or any other things in your daily life, all by your
voice.
It’s a voice-enabled extension for your surroundings
ReSpeaker supports both online cognitive services and offline lightweight speech recognition
engine. You can add ReSpeaker to things around you to make them smart(smarter).
It’s a device for music streaming
Voice interface has never been apart from music entertainment, so does
ReSpeaker. ReSpeaker supports Airplay/DLNA for wireless music streaming. Just connect
ReSpeaker to any ordinary speaker with an AUX cable, then you can start enjoying the music
you love without pressing a single button.
It’s a learning tool for kids
Rather than the on board MT7688 Wi-Fi module which runs the Linux based OpenWrt,
ReSpeaker is also powered by the ATmega32u4 chip and absolutely Arduino compatible,
which means, we can use ReSpeaker as a powerful Arduino board and do many ‘Arduino’
things. It’s for learning, it’s for practicing, and it’s for fun.
Installation-free APP For Everyone
The exposed PCB design does not mean ReSpeaker is just for people who knows a lot about
ReSpeaker uses a user-friendly Web-based App that can be set up by anyone in just minutes. In the App you can
access a range of rich featured applications that ReSpeaker has provided, includes music streaming, file manager,
plug-in, customized settings and more. Click the image below to visit the web app or directly go to: respeaker.io
Always-growing Features
The plug-in system is specially designed for the users to share and download their voice
interactive projects as a simple plug-in to the ReSpeaker module. It has significantly simplified
the use of ReSpeaker as anyone who has a ReSpeaker can install the plug-ins they want with
a single click, and after that they can run voice interaction just like any others.
Developer-friendly
Developers can of course achieve more with the SDK we provide to develop their own voice
interaction projects.
Modular Design and Extendable Add-ons
The far-field MIC Array allows your ReSpeaker to be able to recognize your location and hear
you from across the room even while the music is playing.
And the Grove extension board brings even more possibilities as you can connect various
Grove sensors and actuators to extend its capabilities. The two onboard expansion headers
also offer I2S, I2C, AUX, USB 2.0, GPIOs and many other interfaces that you can use for more
applications.
We make ReSpeaker compatible with the Wio famil for you to add voice interaction with any of
your IoT devices that is built on Wio. Simply pair your ReSpeaker to your Wio product using
our Web App, then you can voice control your Pet Feeder built to dispense treats, or ask your
Smart Plant if she need some water.
We have demos with step-by-step tutorials to help you getting started with your first project
using ReSpeaker.
Voice Interaction Between You And...
AI7688 Wi-Fi Module
Operation system: GNU/Linux based OpenWrt
Wi-Fi Network: Support Legacy 802.11b/g and HT 802.11n modes
Expansion: Two expansion headers for I2C, GPIO and USB 2.0 host
Interfaces: Built-in 3.5mm AUX port, Micro USB and SD card slot
ATMega32U4 Coprocessor
USB CDC virtual serial port for linux console
12 programmable RGB LED indicators
8 on board touch sensors
Codec WM8960
DAC SNR 98dB (‘A’ weighted), THD -84dB at 48kHz, 3.3V
ADC SNR 94dB (‘A’ weighted), THD -82dB at 48kHz, 3.3V
Stereo Class D Speaker Driver with 87% efficiency (1W output)
On-chip Headphone Driver
P:RXWSXWSRZHULQWRȍDW9
7+'G%DWP:615G%ZLWKȍORDG
On-chip PLL provides flexible clocking scheme
Sample rates: 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48 kHz
Power Supply: 5V DC
Dimensions: 70mm diameter
Weight: 17g
1x ReSpeaker Core
1x ReSpeaker Core
1x 8G Class 10 Micro SD Card
Copyright © 2008-2016 Seeed Development Limited All rights reserved
很抱歉,暂时无法提供与“102010088”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+605.8483010000+78.75832
