102110159
102110159
    SEEED(矽递科技)
    ROCK960 BOARD BASED ON THE RK339
102110159 数据手册
      Rock960 Board ‐ Based on the RK3399 SoC ‐ 4GB RAM Version SKU 102110159   Description   The Rock960 is based on the RK3399 SoC which is a Dual Cortex‐A72 + quad Cortex‐A53 CPU, with up to 2.0GHz frequency. This board comes packed with 4GB of RAM, 32GB of on board eMMC storage, USB 3.1 type C with DP, HDMI 2.0 with 4K output, 4 lane M.2 PCI‐E 2.1, and so much more! Features:        RK3399(A72x2+A53x4),4G/32G Mali T860MP4, OpenGL 3.2, OpenCL 1.2 HDMI 2.0 4K@60 USB type C with DP 1.2 + USB 3.0 4 lanes PCIE 2.1 2x2 MIMO 802.11 AC Wi‐Fi, BT 4.1 96boards Low speed/Hight speed expansion Expansion: 1x 40 pin low speed expansion connector – UART, SPI, I2C, GPIO, I2S 1x 60 pin high speed expansion connector – MIPI DSI, USB, MIPI CSI, HSIC, SDIO 1x M.2 key M PCIe connector with support for up to 4‐lane PCIe 2.1 (max bandwidth: 2.0 GB) Misc – Power & u‐boot buttons. 6 LEDS (4x user, 1x Wifi, 1x Bluetooth) Power Supply – 8 to 18V DC input (12V typical) as per 96Boards CE specs; Battery header We also provide a Rock960 2G version, you can check here. Board Overview Technical Details Dimensions 185mm x 113mm x 115mm  Weight  G.W 520g     N.W 517.80g  Battery  Exclude  SoC  Rockchip RK3399  CPU  ARM Cortex‐A72 Dual‐core up to 1.8GHz + Cortex A53 Quad‐core up to 1.4GHz  GPU  ARM Mali T860MP4  RAM  4GB LPDDR3 @ 1866MHz  PMU  RK808‐D  Storage  32GB eMMC 5.1  Ethernet  Port  USB 2.0/3.0 expansion  Wireless  WLAN 802.11 ac/a/b/g/n, 2xMIMO, 2.4GHz and 5Ghz, Bluetooth 4.2. On board  WLAN/BT antennas  USB  1 x USB 3.0 type A and 1 x USB 2.0 type A (host mode only) and 1 x USB 3.0 type C OTG  Display  1 x HDMI 2.0(Type A ‐ full) up to 4Kx2K@60Hz, 1 x 4L ‐ MIPI DSI up to 1080p@60Hz, 1 x  DP 1.2(Type C) up to 4Kx2K@60  Video  Inside decoder: H.264 10bit up to HP level 5.1 ‐ 2160p@60fps (4096x2304), VP9 ‐  2160p@60fps(4096x2304), H.265/HEVC 10bit ‐ 2160p@60fps(4096x2304), MPEG‐1,  MPEG‐2, MPEG‐4, H.263, VP8, VC‐1  Audio  HDMI output  Camera  2 x 4‐lane MIPI CSI  Expansion  Interface  40 pin low speed expansion connector: +1.8V, +5V, DC power, GND, 2UART, 2I2C, SPI,  I2S, 12xGPIO and 60 pin high speed expansion connector: 4L‐MIPI DSI, I2C x2, SPI (48M),  USB 2.0, 2L+4LMIPI CSI  LED  1 x WiFi activity LED(Yellow), 1 x BT activity LED (Blue) and 4 x User LEDs (Green)  Button  Reset button, recovery button  Power  Source  Recommend a 12V@2A adapter with a DC plug which has a 4.75mm outer diameter and  1.7mm center pin with standard center‐positive (EIAJ‐3 Compliant)  OS Support  AOSP/Debian/Ubuntu/Fedora/LibreELEC/Lakka/FlintOS  Size  85mm x 55mm  Part List ROCK960 board 1  12V/2A power adapter  1  Screws Pack  2  Heatsink(22mm x 22mm)  1  Heatsink Plaster  1  Transparent acrylic case  1  Heatsink Case  1  ECCN/HTS ECCN 5A991  HSCODE  8471504090                                                https://www.seeedstudio.com/Rock960%20Board%20‐%20Based%20on%20the%20RK3399%20SoC%20‐%204GB%20RAM%20Version‐p‐3125.html 9‐7‐18
102110159 价格&库存
很抱歉,暂时无法提供与“102110159”相匹配的价格&库存,您可以联系我们找货
