102110198
102110198
    SEEED(矽递科技)
    KHADAS VIM2 S912 EVAL BRD
102110198 数据手册
        Khadas VIM2 Max Open Source SBC/TV Box 3GB+64GB Wi-Fi Gigabit LAN with WOL Multi-System-Compatibility 4K SKU 102110198    Description  Professional | Powerful | Ultimate | Superior | Awesome user experience  Khadas VIM2 is the first and only Amlogic S912 based hobbyist development board on the  market, which makes it interesting by itself, but Khadas also added some interesting features  such as an SPI flash for network boot, Wake‐on‐LAN support, and more.              Features  Excellent performance  1.5GHz 64‐bit Octa‐Core CPU, T820MP3 GPU, and up to 3GB DDR4 & 64GB eMMC.  Unlimited connectivity  2X2 MIMO 802.11ac Wi‐Fi, 4.x Bluetooth, Gbit Lan and a USB‐C(2.0) port.  Advanced Specs  WOL(Wake on Lan) and RSDB Wi‐Fi will improve the user experience steps forward.  Maker friendly  Equipped with 40‐pin GPIO header, cooling fan slot and a programmable MCU.  Multimedia experts  HDMI2.0a and a powerful VPU with 10‐bit 4K H.265/VP9@60fps playback support.  Tiny form factor  Thin and light with a dimensions of credit card.          Highlights  Android 7.1 + Ubuntu + Buildroot + Docker Multi‐OS  Pre‐installed with Android, you can also install Ubuntu, Buidroot, Docker OS, it will bring you a  surprise of using experience.  Amlogic S912 Octa‐core CPU  Rapid and stable performance can give you a high‐speed feedback and smooth response.  DDR4 3GB RAM, eMMC 64GB ROM  It is configured with DDR4 3GB RAM, and eMMC 64GB ROM, thus it can provide enough room  and freedom to install Apps without worrying about running out of space.  Bluetooth 4.2 Connectivity  Easy pairing with most Bluetooth‐enabled devices.  Gigabit LAN  Gigabit LAN can improve the internet speed and the performance to a great extent.  Multiple Use Case  You can turn Khadas VIM2 Max Development Board into SBC, Clusters, Digital Signage,  Robotics, IoT, TV Box.                    Technical Details    Dimensions 82mm x 57.50mm x 11.50mm  Weight  G.W 860g     N.W 710g  Battery  Exclude  SoC  Amlogic S912; 1.5 GHz 64Bit Octa Core ARM Cortex‐A53; 750MHz  ARM Mali‐T820MP3 GPU; HW UHD H.265/VP9 60fps 10bit video  decoder; HDR10 and HLG HDR video processing;  MCU  STM8S003 with Programmable EEPROM  SPI Flash  2MB  DDR4  3GB  EMMC  64GB      Wi‐Fi  AP6359SA, 2X2 MIMO with RSDB  Bluetooth  V4.2  LAN  10/100 / 1000M  WOL  Wake up & on Lan  IR Receiver  2 Channels  HDMI 2.0a  Type‐A Female, up to 4K@60Hz  HDMI CEC  Yes  TF Card  Molex Slot  USB2.0 HOST  x2 (900mA & 500mA Load)  USB Type‐C  USB2.0 OTG & DC IN  Wide Input Voltage  Range from 5V to 9V, Recommend 5.0V  Current Limit Switch  Programmable, 3.0A as default (up to 4.0A)  VIN (Extra Power IN)  4‐Pins, 1.25mm Pitch Header  RTC & Battery Header  0.8mm Pitch Header  Cooling Fan Header  3 Levels Speed, with a 0.8mm Pitch Header    40‐Pins I/O Header  2.54mm, USB, I2C, I2S, SPDIF, UART, PWM, ADC, ISO7816  FPC Connector  10‐Pins, 0.5mm Pitch, with I2C, IOs  Pogo Pads Array  USB, I2C, DVB‐Bus, IOs  Pogo Pads MCU  SWIM, UART, ADC, NRST  Pogo Pads for VIN  System Power Input  Buttons  x3 (Power / Func / Reset)  LEDs  Blue LED x1, White LED x1  Mounting Holes  Size M2 x 4  Android  Nougat (7.1)  Ubuntu  Ubuntu 16.04+  UEFI  Developing  Part List  Khadas VIM2 Max Open Source TV  Box with case 1  Type‐C USB cable  1  ECCN/HTS  ECCN   5A002.a.1                        https://www.seeedstudio.com/Khadas%20VIM2%20Max%20Open%20Source%20SBC/TV%20Box%203GB+64GB%20Wi‐Fi%20Gigabit%20LAN%20with%20WOL%20Multi‐System‐Compatibility%204K‐p‐3190.html 11‐7‐18
102110198 价格&库存
很抱歉,暂时无法提供与“102110198”相匹配的价格&库存,您可以联系我们找货
