Sipeed Lichee Nano Linux Development Board
16M Flash Version
SKU 102110199
Lichee Nano is an SD Card Sized Linux Development Board Powered by Allwinner F1C100s
ARM9 Processor
Features/Specifications
CPU
‐Allwinner F1C100s, ARM 926EJS processor,up to 900MHz
Memory & storage
‐32MB DDR integrated into SoC, 16MB SPI Flash
‐Onboard TF Slot, can be boot from TF Card,
Display
‐40‐pin RGB LCD FPC connector supporting 272×480, 480×800, 1024×600
and other resolutions resistive displays(and capacitive displays trough the adapter board).
‐Support 720P video output, support video stream decoding such as H.264 / MPEG
Communication Interface
‐SDIO for WiFi module
‐SPI x2, TWI x3, UART x3
‐OTG USB x1, TV out
Other interface
‐PWM x2, LRADC x1
‐Headphone output x2, Mic x1
Electrical characteristics
‐Input 5V via micro USB port, 3.3 to 5V via pin
‐Output – 3.3V, selectable input RTC voltage
‐Power Consumption – 54mA (idle) with Linux, 250mA with display
‐Storage Temperature: ‐40~125°C; operating: ‐20 to 70°C
Software and development environment
Support 3.10 BSP linux,
Support 4.19 mainline linux,
Support xboot bare metal development environment
Support RT‐Thread
Target application scenario:
IoT applications using more complex communication interfaces and protocols
The application of human‐computer interaction interface that needs more beautiful and
complex logic
Application scenarios that require more operations (as opposed to common MCUs)
Need to use open source software under Linux for rapid development scenarios
High‐end geek players balance in size, performance and ease of use.
Entry level player, software engineer, hardware diy using familiar language
Size and weight
Core board size
25.4x33.0mm
Core board weight
4.2±0.2g
Precautions
start up
Nano needs card boot (or solder SPI flash), only plug in USB
without any phenomenon
System debug serial port
UART0, specific position reference pin diagram
USB interface
OTG usb, power and communication
Operating temperature
‐20~70
Part List
Lichee Nano
x1
WiFi Module
x1
OTG
x1
ECCN/HTS
ECCN
3A991.a
HSCODE
8517709000
https://www.seeedstudio.com/Sipeed‐Lichee‐Nano‐Linux‐Development‐Board‐p‐2892.html/3‐20‐19
很抱歉,暂时无法提供与“102110199”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+122.60160
- 200+47.44440
- 500+45.78120
- 1000+44.96040
