102110201
102110201
    SEEED(矽递科技)
    F1C100s Sipeed Lichee Nano 16M + WiFi - ARM9 MPU 评估板 - 嵌入式
102110201 数据手册
    DESCRIPTION SKU 102110201 Lichee Nano is an SD Card Sized Linux Development Board Powered by Allwinner F1C100s ARM9 Processor Features/Specifications ‐Allwinner F1C100s, ARM 926EJS processor,up to 900MHz ‐32MB DDR integrated into SoC, 16MB SPI Flash ‐Onboard TF Slot, can be boot from TF Card, ‐40‐pin RGB LCD FPC connector supporting 272×480, 480×800, 1024×600 and other resolutions resistive displays(and capacitive displays trough the adapter board). ‐Support 720P video output, support video stream decoding such as H.264 / MPEG ‐SDIO for WiFi module ‐SPI x2, TWI x3, UART x3 ‐OTG USB x1, TV out ‐PWM x2, LRADC x1 ‐Headphone output x2, Mic x1 ‐Input 5V via micro USB port, 3.3 to 5V via pin ‐Output – 3.3V, selectable input RTC voltage ‐Power Consumption – 54mA (idle) with Linux, 250mA with display ‐Storage Temperature: ‐40~125°C; operating: ‐20 to 70°C           Software and development environment Support 3.10 BSP linux, Support 4.19 mainline linux, Support xboot bare metal development environment Support RT‐Thread Target application scenario: IoT applications using more complex communication interfaces and protocols The application of human‐computer interaction interface that needs more beautiful and complex logic Application scenarios that require more operations (as opposed to common MCUs) Need to use open source software under Linux for rapid development scenarios High‐end geek players balance in size, performance and ease of use. Entry level player, software engineer, hardware diy using familiar language Size and weight Core board size 25.4x33.0mm Core board weight 4.2±0.2g Precautions start up Nano needs card boot (or solder SPI flash), only plug in USB without any phenomenon System debug serial port UART0, specific position reference pin diagram USB interface OTG usb, power and communication Operating temperature ‐20~70 Part List Lichee Nano x1 WiFi Module x1 OTG x1 ECCN/HTS ECCN 3A991.a HSCODE 8517709000 https://www.seeedstudio.com/Sipeed‐Lichee‐Nano‐Linux‐Development‐Board‐16M‐Flash‐WiFi‐Version‐p‐2893.html/3‐20‐19
102110201 价格&库存
很抱歉,暂时无法提供与“102110201”相匹配的价格&库存,您可以联系我们找货
  • 1+132.194291+17.08601
