ROCK PI S - Mini Computer with Rockchip RK3308 - 512MB
RAM
SKU 102110364
Rock Pi S is a Single-board computer(SBC) with a small size and high-performance cost ratio
Looking for a tiny SBC for some small projects? You must take a look at Rock Pi S.
The Rock Pi S is a single-board computer(SBC) that equips an RK3308 Rockchip by Radxa.
It is assembled by a 64bits quad-core processor, USB, ethernet and voice detection engine
at the size of 1.7 inches. The Rock Pi S is suitable for voice applications and some IoT
projects. What ‘s more? The Rock Pi S has a 26-pin expansion header which includes 4 I2C
interfaces, 3 PWM interfaces, 2 SPI interfaces, 3 UART interfaces, and one I2SO interface.
All these functional interfaces can be embedded into 1.7 inches tinny Pi. This little board is
able to support Debian system successfully, and there are wifi and blue tooth module on
this board as well. It is a good idea to develop this board into a central controller of the
media center with a tiny size and attractive price.
I hope you enjoy your own project with this high-performance cost ratio board.
Features
Rockchip RK3308 Quad A35 64bit processor with built-in VAD
512 MB RAM
USB 2.0 OTG(type-C) + USB 2.0 HOST(type-A)
RJ45 10/100Mbit Ethernet
802.11 b/g/n Wifi +bluetooth 4.0 with external antenna connector
26 pin GPIO header
26 pin voice/audio header includes I2C, PCM, TDM, PDM, SPDIF, and HDMI ARC
Size 1.7x1.7 inch (~38.1mmx38.1mm)
Debian and Buildroot successfully tested
Related products
ROCK PI S - Mini Computer with Rockchip RK3308 - 256RAM
ROCK PI S - Mini Computer with Rockchip RK3308 - 512MB RAM/1GB NAND Flash
ROCK Pi 4 Model A 1GB
ROCK Pi 4 Model A 2GB
ROCK Pi 4 Model A 4GB
ROCK Pi 4 Model B 1GB
ROCK Pi 4 Model B 2GB
ROCK Pi 4 Model B 4GB
Radxa Rock pro
ECCN/HTS
HSCODE
UPC
8543709990
This guide is designed for ROCK Pi S enthusiast. The purpose is to learn about the
ROCK Pi S board as well as how to prepare and set up for basic use. We will introduce
the board information as much as possible.
What you need
Necessary
ROCK Pi S main board
One of the Storage media below:
o μSD card, larger than 8GB.
USB type C to type A cable
o For both power and USB communication(adb/fastboot) with HOST PC.
PC/Laptop which has USB ports
o The ROCK Pi S can be powered from the PC/Laptop USB ports directly
Optional
μSD Card Reader
o For flashing the image into μSD Card or eMMC Module.
USB to TTL serial cable
o For serial console, low level troubleshooting, development etc.
Ethernet cable
o ROCK Pi S supports Internet access via WIFI or Ethernet.
o An Ethernet cable is used to connect your ROCK Pi S to a local network and the
Internet.
Close look of ROCK Pi S
ROCK Pi S front view
ROCK Pi S front with an angle view
ROCK Pi S back view
Features
Model
ROCK Pi S
SoC RK3308
Processor Quad Cortex-A35 ARM 64bits processor
frequency up to 1.3GHz
Memory 256MB or 512MB DDR3
Storage
MicroSD(TF), optional on board 1/2/4/8Gb NAND flash
802.11 b/g/n wifi
Wireless Bluetooth 4.0(rtl8723DS)
external antenna
USB
USB2.0 Type-A HOST x1
USB3.0 Type-C OTG x1
Key
maskrom x1
reset x1
Ethernet 100MB ethernet, optional PoE(additional HAT requried)
IO
I2C x4
PWM x3
SPI x2
UART x3
I2S0 x1
5V DC power in x2
3.3V DC power in x2
Others
Power
USB Type-C DC 5V
Size
1.7inch square
Starting the board for the first
time
ROCK Pi S can be started with μSD Card.
1. Prepare the image
When start system with μSD Card
Insert the μSD Card into μSD Card Reader, which connects to host computer.
2. Write Image to uSD card
Download the flash tool, etcher, from Downloads. Choose the right version for your host
operation system. Here we operate on host Ubuntu 16.04.
After unpacking the package, we run the tool by executing the command
$ ./etcher-etcher-electron-1.4.5-x86_64.AppImage
If you get an error message: "No polkit authentication agent found" you can try and start
it with sudo, but do know that this is running the tool as root.
In the etcher window, click Select image.
In the etcher window, click Select Drive.
In the etcher window, click Flash.
In the etcher window, once it shows us Flash Complete! It is done and can be put into the
ROCK Pi S.
3. Boot the board
Now insert the uSD card to the board.
Use a USB C to USB A cable, connect the board to your PC
ROCK Pi S will boot, the green power led is on, and after a while, the blue led start blinking
(Optional)Use a USB to TTL serial cable to make a connection between your PC and ROCK
Pi S. See Serial Console
4. Access from the Host PC/Laptop
Option 1: USB access(adb)
By default, the ROCK Pi S Linux image enables adbd services, which is a debug bridge
from Android now ported on Linux. With one USB A to C cable you can power and
access the board, very handy.
To use adb, you need to install adb tool on the PC/Laptop. Check instructions
for Windows and Linux.
After you have adb installed successfully, run the following command on console to
login the shell of ROCK Pi S:
adb shell
Check Using adb.
Option 2: Serial console
Check Serial Console
Option 3: SSH
SSH server is enabled on port 22 of ROCK Pi S default image.
To access ROCK Pi S by SSH, try
ping rockpis.local
ssh rock@rockpis.local
or if your router/network doesn't support Local Domain, you need to check your
network/router administrator page and look for the ROCK Pi S ip address.
ping ip-of-device
ssh rock@ip-of-device
Note: You can also get the IP of ROCK Pi S from option 1 or option 2 if you can not
access network administrator page.
Troubleshooting
Refer Troubleshooting page
Post your issue on the forum: https://forum.radxa.com/c/rockpiS
Network state
Look at network configure:
$ sudo ifconfig
Test network:
$ ping -c 5 www.google.com
WIFI Connection
Check WIFI Connection.
Bluetooth
Check Bluetooth.
Buttons
ROCK Pi S have reset key and maskrom key:
Reset key:
Push this key ROCK Pi S can reset hardware.
Maskrom key:
ROCK Pi S support boot on SD NAND flash,SD NAND was booting before TF card on
default,push maskrom key can ignore the SD NAND flash.
GPIO
ROCK Pi S has two 26-pin expansion header. Each pin is distinguished by color, more
information click here
Development for GPIO ROCK Pi S support libmraa GPIO library, click here to get more
information.
Using OTG
ROCK Pi S has an USB type-C OTG connector, you can using it write or read data by
PC to ROCK Pi S, more help click here
https://www.seeedstudio.com/ROCK-PI-S-Mini-Computer-with-Rockchip-RK3308-512MB-RAM-4Gb-NAND-Flash-p-4282.html/11-19-19
很抱歉,暂时无法提供与“102110364”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 10000+152.7569410000+19.85116
