102110551
102110551
    SEEED(矽递科技)
    7-INCH SMART DISPLAY (POWERED BY
102110551 数据手册
7-Inch Smart Display (Powered by SSD202 SoC) SKU 102110551 The 7-inch smart display features an ultra-small SoM (System on Module) module based on SigmaStar SSD202 SoC (ARM Cortex A7 processor), with a frequency up to 1.2GHz, 256KB L2-Cache, built-in dual MAC, one PHY, and supporting dual 100M Ethernet interfaces. PRODUCT DETAILS Features • Powered by SSD202 SoC running at up to 1.2GHz • Supports 1920x1080 at 60 fps with H.265/HEVC decoder • DDR2/DDR3 128MB onboard RAM with auto-refresh and self-refresh modes • 256MB onboard flash and micro-SD card slot for more storage • Network connectivity using built-in Wi-Fi, Ethernet, and 4G • Rich I/O peripherals for more connectivity Description The 7-inch smart display features an ultra-small SoM (System on Module) module based on SigmaStar SSD202 SoC (ARM Cortex A7 processor), with a frequency up to 1.2GHz, 256KB L2-Cache, built-in dual MAC, one PHY, and supporting dual 100M Ethernet interfaces. The memory management supports DMA engine. It integrates H.264/AVC and H.265/HEVC decoders and supports max. resolution FHD (1920x1080)/60 fps decode. The 7-inch smart display is equipped with TTL display driver interface, TF card socket, Ethernet, MAC, audio interface, speaker interface, USB2.0, Wi-Fi, and Sim Card Slot. Specifications Specification CPU Details SigmaStar SSD202 ARM® Cortex-A7 dual-core processor, up to 1.2GHz Supports max resolution FHD(1920x1080)/60 fps decode, H.265/HEVC decoder, I/P/B slices, all intra-prediction modes, Video Processor all inter-prediction modes, supports max resolution HD(1920x1080)/60 fps decode RAM Built-in DDR2/DDR3 128MB memory, support auto-refresh and self-refresh modes Storage Supports 1/2/4-bit SPI-NOR/SPI-NAND Flash, 256MB Supported OS Linux Specification Details Ethernet 1-channel 10/100Mbps half duplex/full duplex Ethernet Equipped with Singmaster Wi-Fi chip (SSW101B), WIFI with high performance and 500m transmission distance in open space Video output interface: Display -1 x RGB, support FHD (1920x1080)/60 fps decoding output, with 1024*600 IPS RGB module by default Audio 1 x left and right channel speaker (PH-4 connector) 1x DEBUG(PM_UART) Serial port 1 x RS232 1 x RS485 USB 1x USB 2.0(USB female) TF card 1 x Micro-SD card (support SDIO2.0) RTC 1220 button battery, easy to maintain Extension interface Power input PCBA dimensions 4 x GPIO Default USB Type-C power supply; Optional 4.5~30V DC @1A power supply, rated voltage 12V DC 122mm x 73mm Specification Operating temperature Storage temperature Details -10~70℃ -20~85℃ Applications • Smart building indoor intercom • Smart home central control • 86-box family central control • Elevator floor display • IP network broadcasting device • Speech recognition equipment Hardware Overview Part List 1 x 7-Inch Smart Display (Powered by SSD202 SoC) ECCN/HTS HSCODE 8548900030 USHSCODE 8543908885 UPC https://www.seeedstudio.com/SigmastarSSD202-7-inch-Smart-Display-p-4885.html/3-15-22
102110551 价格&库存
很抱歉,暂时无法提供与“102110551”相匹配的价格&库存,您可以联系我们找货
