102990161
102990161
    SEEED(矽递科技)
    INTEL EDISON EDISON EVAL BRD
102990161 数据手册
Page 1 of 2 Intel® Edison SKU: 102990161 (images/102990161 1_02.jpg) Description Brief Introduction: The Intel® Edison development platform is bringing down barriers in the world of wearables and IoT technology. Dimensions:32.5 x 25.0 x 3.9 mm Main Features: • Uses a 22nm Intel® SoC that includes a dual core, dual threaded Intel® Atom™ CPU at 500MHz and a 32-bit Intel® Quark™ microcontroller at 100 MHz.  It supports 40 GPIOs and includes 1GB LPDDR3, 4 GB EMMC, and dual-band WiFi and BTLE on a module slightly larger than a postage stamp. • The Intel Edison module will initially support development with Arduino* and C/C++, followed by Page 2 of 2 Node.JS, Python, RTOS, and Visual Programming support in the near future. • It includes a device-to-device and device-to-cloud connectivity framework to enable cross-device communication and a cloud-based, multi-tenant, time-series analytics service. Specification: Physica Form factor Dimensions Operating temperature Connector Board with 70-pin connector 32.5 x 25.0 x 3.9 mm 0 to 40 degC Hirose DF40 Series (1.5mm, 2.0mm, or  3.0mm stack height) Memory  Max Memory size Memory type Physical add. Ext. # of  DIMMs ECC Memory supported:  4GB DDR3, Nand Flash 32-bit 0 NO External Interfaces Total of 40 GPIOs which can be configured as: SD Card 1 Interface UART 2 Controllers I2C 2 Controllers SPI 1 Controller with 2 chip selects I2S 1 Controller GPIO Additional 12 (with 4 capable of PWM) USB 2.0 1 OTG Controller Clock Output 32 KHz, 19.2 MHz Major Edison Components   SoC RAM Flash Storage WiFi Bluetooth 22nm Intel SoC includes: a dual core, dual threaded Intel Atom CPU at 500MHz, and a 32-bit Intel Quark microcontroller at 100 MHz 1 GB LPDDR3 POP memory 4 GB eMMC Broadcom 43340 802.11 a/b/g/n Dual-band (2.4 and 5 GHz) On board antenna or external antenna SKU configurations BT 4.0 Power Input Output Power 3.3V – 4.5V 100ma @3.3V and 100ma @ 1.8V Standby (No radios): 13mW Standby (BT 4.0): 21.5mW Standby (WiFi): 35 mW Firmware + Software CPU OS Development Environments MCU OS Development Environments Yocto Linux v1.6 Arduino IDE Eclipse supporting: C, C++ & Python Intel XDK supporting: Node.JS & HTML5 RTOS MCU SDK and IDE http://www.seeedstudio.com/depot/Intel-Edison-p-2150.html 12/2/2015
102990161 价格&库存
很抱歉,暂时无法提供与“102990161”相匹配的价格&库存,您可以联系我们找货
