102990193
102990193
    SEEED(矽递科技)
    PHOENARD ATMEGA2560 EVAL BRD
102990193 数据手册
Phoenard SKU: 102990193 Description Phoenard is a programmable controller and development board with full Arduino programming support. Use the Phoenard to control robots, machines, lights, wearables and more, making use of the onboard wireless communication (GSM, WiFi, Bluetooth) and motion sensors. The 16-bit color LCD touchscreen can be used to display user interfaces, for which we provide a full-fledged Arduino library. Display and control buttons, sliders, gauges, graphs and more with very little programming experience required. Design your own widgets and visuals for experienced users. Build interactive solutions to everyday projects! Multiple Arduino programs, called sketches, can be stored on the Micro-SD card of the device. The installed on-board software and firmware enables multi-sketch operation. Switch between all your sketches in the home menu while away from the computer. Your electronics projects can be docked to the bottom 30-pin connector, which exposes basic design needs such as digital pins, 6 analog input pins, 3v3 power and I2C/SPI/Serial digital interfaces. The connector doubles as a standard docking connector providing audio to the right pins, allowing the device to play music when docked on a docking music station. Features Safe operating conditions Temperature: -10 ~ 60 degrees celcius Humidity: 20% - 90% Power Battery: 1050 mAh Li-Ion Charging: 5V 0.5A USB Main board voltage: 3v3 Processor and memory Name: AVR Atmega2560 Firmware: Custom firmware 'phoenboot' Type: Single-core 8-bit RISC Speed: 16 Mhz Flash memory: 256Kb RAM: 8Kb EEPROM: 4Kb Interfaces: Serial UART, I2C, SPI External SPI-RAM: 32Kb Micro-SD: FAT16 and FAT32 ready Screen Name: ILI9325 Size: 2.8 inch Resolution: 320x240 pixels Color: 16-bit color Interface: 8-bit parallel bus interface Touchscreen: resistive Wireless WiFi: ESP8266 module Bluetooth: HM-11 module SIM908 module: GSM, GPRS and GPS in one package Sim card: standard size Sensors MPU6050: 3-axis accelerometer and gyro HMC5883l: 3-axis magnetometer BMP180: barometer and temperature SELECT button: tactile input Media controller Name: VS1053b Media: MP3/ACC/AAC+/WAV/AMR/MIDI Control: SPI (Audio) and Serial (MIDI only) Output: 3.5mm Audio jack and bottom connector A starters guide together with documentation and software examples is available on our website: Getting started Software documentation Forums Copyright © 2008-2015 Seeed Technology Co., Ltd All rights reserved
102990193 价格&库存
很抱歉,暂时无法提供与“102990193”相匹配的价格&库存,您可以联系我们找货
