102990218
102990218
    SEEED(矽递科技)
    AUTOMATIONBOARD ATMEGA328P EVAL
102990218 数据手册
      Automation Board SKU 102990218   Thinking about using Arduino to automate your home? Do it easily with our compatible board!  The Automation Board is 100% compatible with the Arduino Uno. This way it allows the  enjoyment of all the easy programming and libraries that Arduino provides. It's a strong and  versatile board, with multiples resources to develop a fully automation system. The Automation  Board dispenses the use of power sources.      Features  Onboard Power Supply  Thanks to a power source soldered onto the board itself, it is supplied directly from the  electrical grid with voltages between 100 to 240VAC and 50 or 60Hz making it adaptable to any  electrical grid around the world.   Relay Triggering  The Automation Board has 4 relays to trigger alarms, electronic locks, fans, lamps and any other  compatible charge.   Sensoring  The pins that are ready to connect your sensors, can be digital or analog, including 5v and GND,  making the connections easy and organized. You will be able to connect several kinds of sensors  such as temperature, humidity, or like this example, motion .  You can connect an infrared receiver and use it to create a communication with any remote  control like the one you use for your TV.   Internet Connection  The Automation Board, like the Arduino, allows you to use shields. You can also use minishields  for Garagino like this Mini Ethernet Shield.   RS‐485 Communication  Also it's possible to make an RS‐485 connection through the Automation Board, allowing  applications in industrial automation systems or in some places that has electromagnetic  interference. You will even be able to use specific programs to control professional automation  systems.   Wireless Communication  Through the dedicated headers for XBee modules you will be able to connect as many  Automation Boards as you wish to a network, or even a wireless connection with a PC through a  simple Dongle USB for XBee.      Specification Technical Specs  Microcontroller: Atmel ATmega328P‐PU (DIP)   Bootloader: Optiboot (same as Arduino UNO)   Relays: 100V/10A ‐ 250V/7A   Power Supply: 100 ‐ 240Vac   Digital Circuit Operating Voltage: 5V   Internal voltage regulator and logic converter for XBee modules   Digital I/O Pins: 14 (D0~D8 Reserved / D9~D13 Free)   Analog Input Pins: 6 (A0 and A1 Reserved /A2~A5 Free)   Dimensions: 130 x 112 x 26mm ‐ 5,1 x 4,4 x 1'' (LengthxWidthxHeight)  Part List 1 x Automation Board    For any technical support or suggestion, please kindly go to our forum.    Technical details  Dimensions  0mm x0mm x0mm  Weight  G.W 186g  Battery  Exclude  ECCN/HTS  HSCODE    8538900000                                             https://www.seeedstudio.com/Automation‐Board‐p‐2596.html/4‐2‐19
102990218 价格&库存
很抱歉,暂时无法提供与“102990218”相匹配的价格&库存,您可以联系我们找货
