102990228
102990228
    SEEED(矽递科技)
    CRAZYFLIE 2.0 BUZZER DECK BOARD
102990228 数据手册
  Crazyflie 2.0 - Buzzer deck SKU 102990228   Description Sometimes LED feedback isn’t enough, like when you’re flying around in a lab or a living room. With the buzzer deck you’ll get audio feedback on system events, like low battery or charging completed. Or why not create your own melodies that will play while you’re buzzing around. To get started using the buzzer deck there’s already a few melodies pre-programmed in the Crazyflie 2.0 latest firmware. This product is intended to be used together with the Crazyflie 2.0 nano quadcopter and uses its expansion board system. Please have a look at the buyers guide for more info about the Crazyflie 2.0 ecosystem. For more information about how to use the expansion decks check out the getting started with expansion deckspage. FEATURES   • • Low profile piezo buzzer for tone and melody generation Automatic detection of deck SPECIFICATIONS   • • Based on the CMT-1203-SMT 1-wire memory for automatic deck detection MECHANICAL SPECIFICATION    • • • Weight: 1.8g Size (WxHxD): 25x27x4mm Designed for mounting above or under the Crazyflie 2.0 PART LIST  • 1 x Buzzer deck SUPPORT If you have any further question for technical support, please contact support@bitcraze.se.                   https://www.seeedstudio.com/Crazyflie-2.0-Buzzer-deck-p-2619.html 2/28/2017
102990228 价格&库存
很抱歉,暂时无法提供与“102990228”相匹配的价格&库存,您可以联系我们找货
