102990837
102990837
    SEEED(矽递科技)
    WIO LTE US VERSION - 4G, CAT.1,
102990837 数据手册
      Wio LTE US Version ‐ 4G, Cat.1, GNSS, JavaScript(Espruino) Compatible SKU 102990837   Wio Tracker (Wireless Input Output) is an open source gateway which enable faster IoT GPS  solutions. It is Arduino and Grove compatible development boards that helps you track nearly  any moving thing on the planet and then upload that data wirelessly. The Wio LTE is the LTE  version of Wio Tracker, so now we’ve got 2 versions of Wio Tracker and the LTE (4G) version  will make some differences.    There are three main updates comparing the Wio LTE to the 2G version. Firstly, from its name  we know that the Wio LTE supports LTE (4G) communication which is much faster and popular  than 2G. Secondly, the Wio LTE supports in total 4 different GNSS – GPS, Beidou, GLONSS and  Galileo, the QZSS is also supported as bonus. With more GNSS support, positioning will be more  accurate. Thirdly, the Wio LTE‘s MCU is upgraded to STM32F405RG, which is based on Cortex‐ M4, makes the Wio LTE 5 times faster than the 2G version. What’s more, the flash and RAM  have also been raised to 1Mbytes and 192+4k bytes.    Apart from the three main updates, the LTE version is almost the same as the 2G version. If  your project is using the 2G version, it would be very easy to update to the LTE version because  we have prepared transplantable and expansible AT command library. The Arduino and Grove  compatibility allows for quicker development through numerous libraries and a supportive  community. The GPS library which will be available with the board is not just limited to Arduino  – it can function just as well if you chose to develop in C/C++. With the onboard 6 Grove  connections, developers can create any combination of our 180+ sensors and actuators to build  project and solve any problem. Simplifying the prototyping and development phase is our goal.  The Wio LTE is well suited for outdoor projects where the device can connect to the GPS  satellites and provide a real‐time location of the item it is attached to. The LTE provides a wide  bandwidth which allows much faster interaction between the user and device. If you are going  to build projects like a bicycle sharing service, tracking pets or livestock, locating a vehicle, or  even keeping track of a child, the Wio LTE is the best solution.        Note:  The suggest power supply for Wio LTE products is 5V/2A; The board may not be able to power up when the current is below 1A.  Please always plug a 3.7V Lipo battery in case USB power supply is not sufficient.  When the signal is not good, there will be noise while calling.  We have developed 4 different versions of Wio LTE for different regions. This is the Wio LTE US version, except this version, the others also support GNSS, below table shows the difference between each version. For more detail information, please refer to this manual.  https://github.com/SeeedDocument/Bazzar_Attachment/raw/master/102990837/Quectel_EC2 1_Hardware_Design_V1.4.pdf        Features      Low‐cost, low‐power LTE connectivity optimized for broad‐ band IoT applications  Worldwide LTE and UMTS/HSPA+  Embedded power management unit (PMU) featuring ultra‐low deep‐sleep current consumption  GPS/BeiDou/GLONASS/Galileo and QZSS       Transplantable and expansible AT Command Library for Wio Tracker  Arduino IDE compatible  JavaScript(Espruino) Compatible  6 Grove Connectors  Nano SIM and TF card 2 in 1 socket    Technical details  Dimensions  54.7mm x48.2mm x0mm  Weight  G.W 101g  Battery  Lithium Cells/Batteries packed with  equipment UN3481 ‐PI966  Part List  Wio LTE ‐ 4G, Cat.1, GNSS,  1  Espruino Compatible  LTE Antenna  2  GPS Antenna  1  Lithium Polymer Battery  1  3.7V‐ 1050mAH;46.5*45*4.8mm JST1.0  Micro USB cable,200mm  in length    1  ECCN/HTS  ECCN  3A991.a  HSCODE  8543709990                       https://www.seeedstudio.com/Wio‐LTE‐US‐Version‐4G‐Cat‐1‐GNSS‐JavaScript‐Espruino‐Compatible‐p‐2957.html//3‐6‐19
102990837 价格&库存
很抱歉,暂时无法提供与“102990837”相匹配的价格&库存,您可以联系我们找货
