102990923
102990923
    SEEED(矽递科技)
    WIO LTE EU VERSION 4G CAT.1 GNSS
102990923 数据手册
            Wio LTE EU Version ‐ 4G, Cat.1, GNSS, Espruino  Compatible  SKU 102990923  Description  Wio Tracker (Wireless Input Output) is an open source gateway which enable faster IoT GPS  solutions. It is Arduino and Grove compatible development boards that helps you track nearly  any moving thing on the planet and then upload that data wirelessly. The Wio LTE is the LTE  version of Wio Tracker, so now we’ve got 2 versions of Wio Tracker and the LTE (4G) version  will make some differences.     There are three main updates comparing the Wio LTE to the 2G version. Firstly, from its name  we know that the Wio LTE supports LTE (4G) communication which is much faster and popular  than 2G. Secondly, the Wio LTE supports in total 4 different GNSS – GPS, Beidou, GLONSS and  Galileo, the QZSS is also supported as bonus. With more GNSS support, positioning will be more  accurate. Thirdly, the Wio LTE‘s MCU is upgraded to STM32, which is based on Cortex‐M4,  makes the Wio LTE 5 times faster than the 2G version. What’s more, the flash and RAM have  also been raised to 1Mbytes and 192+4k bytes.   Apart from the three main updates, the LTE version is almost the same as the 2G version. If  your project is using the 2G version, it would be very easy to update to the LTE version because  we have prepared transplantable and expansible AT command library. The Arduino and Grove  compatibility allows for quicker development through numerous libraries and a supportive  community. The GPS library which will be available with the board is not just limited to Arduino  – it can function just as well if you chose to develop in C/C++. With the onboard 6 Grove  connections, developers can create any combination of our 180+ sensors and actuators to build  project and solve any problem. Simplifying the prototyping and development phase is our goal.     The Wio LTE is well suited for outdoor projects where the device can connect to the GPS  satellites and provide a real‐time location of the item it is attached to. The LTE provides a wide  bandwidth which allows much faster interaction between the user and device. If you are going  to build  projects like a bicycle sharing service, tracking pets or livestock, locating a vehicle, or  even keeping track of a child, the Wio LTE is the best solution.     Note:  This is the EU version of Wio LTE,and there are in total 4 different versions. Here is a table to  show the main difference between different versions. For more detail information, please refer  to this manual.  https://github.com/SeeedDocument/Bazzar_Attachment/raw/master/102990837/Quectel_EC21_Hardware_Design_V1.4.pdf          Technical Details    Weight G.W 18g      Battery  Exclude    Part List    Wio LTE EU Version ‐ 4G, Cat.1, GNSS, Espruino Compatible 1  LTE Antenna  1  GPS Antenna  1                                       https://www.seeedstudio.com/Wio‐LTE‐EU‐Version‐‐‐4G%2C‐Cat.1%2C‐GNSS%2C‐Espruino‐Compatible‐p‐2998.html 12‐12‐17
102990923 价格&库存
很抱歉,暂时无法提供与“102990923”相匹配的价格&库存,您可以联系我们找货
