102990965
102990965
    SEEED(矽递科技)
    模块
    WiFi 802.11b/g/n RF 收发器模块 2.4GHz 集成式,跟踪 卡边
102990965 数据手册
    Seeedstudio ESP8285 Wi‐Fi SoC Module  SKU 102990965          Description  ESP‐01M can be widely used in various occasions for networking, home automation, industrial wireless  control,  baby  monitors,  wearable  electronics,  infinite  position  sensing  device,  wireless  positioning  system, signal and other networking applications, networking applications is the ideal solution.  ESP‐01M uses the DIP plug‐in package, the unique design, so that it can be flexible docking to existing  products,  especially  suitable  for  automation,  large‐scale,  modern  production  of  low  cost,  convenient  application in various networking hardware terminal applications.      Features   The smallest 802.11b/g/n Wi‐Fi SoC module   Uses low power 32bit CPU and compatible with application processor   Main frequency up to 160MHz   Built in 10Bit high precision ADC   Support UART/GPIO/PWM/ADC interface   Integrate Wi‐Fi MAC/BB/RF/PA/LNA   Support multiple sleep modes   Standby power consumption as low as 1.0mW   Embedded Lwip protocol stack   Support STA/AP/STA+AP work model   Support Smart Config/AirKiss   Series Rate up to 4Mbps   Universal AT instruction   Support serial local upgrade and remote firmware upgrade   Small size 18*18*2.8mm            Technical Details    Weight  G.W 4g    N.W 1.5g  Battery  Exclude  Support Interface  UART/GPIO/ADC/PWM  SPI Flash  1MB  I/O Put  11  Series Rate  Support 300~4608000 bps, default 115200 bps  RF Range  2412~2484MHz  Antenna  Embedded PCB Antenna, gain 2dBi  Transmitted power  802.11b  16±2dBm(@11Mbps)  802.11g  14±2dBm(@54Mbps)  802.11n  13±2dBm(@HT20,MCS7)  Receiver sensitivity  CCK, 1 Mbps  ‐90dBm  CCK, 11 Mbps  ‐85dBm  6 Mbps (1/2 BPSK)  ‐88dBm  54 Mbps (3/4 64‐QAM)  ‐70dBm  HT20, MCS7 (65 Mbps, 72 Mbps)  ‐67dBm  Power waste  Continue sending=>average value  ~71mA, Max: 300mA  Modem Sleep  ~20mA  Light Sleep  ~2mA  Deep Sleep  ~0.02mA  Security  WEP/WPA‐PSK/WPA2‐PSK  Power Supply Range  Voltage  3.0V~3.6V  Current  >300mA  Working Temperature  ‐20°C~85°C  Storage environment  ‐40°C~90°C,
102990965 价格&库存
很抱歉,暂时无法提供与“102990965”相匹配的价格&库存,您可以联系我们找货
  • 1+25.921181+3.35988
